Old 07-29-2018, 08:43 AM   #1
MikeCofield
Which manifolds should I use for 5,3Ls install
Have a friend installing a 5.3Ls in a 72 suburban , any tips on which exhaust manifolds he should use
MikeCofield is offline   Reply With Quote
Old 07-29-2018, 09:02 AM   #2
jessemthompson
Re: Which manifolds should I use for 5,3Ls install
Motor mounts make a difference on what headers or manifolds fit well. A lot of guys like the TRAILBLAZER SS manifolds. Try over in the LS swap section.
http://67-72chevytrucks.com/aboard/f...play.php?f=206
jessemthompson is offline   Reply With Quote
Old 07-29-2018, 12:49 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I bought these.
https://www.ebay.com/itm/Hooker-Head...sid=m570.l1313
Worked like a champ.
I think you can get them plain, painted, or ceramic coated......
LockDoc
Leon
Old 07-31-2018, 11:18 PM   #4
87Skier
87Skier's Avatar
Originally Posted by LockDoc View Post
I bought these.
LockDoc
I got the same set for my 72 Jimmy 4x4.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 07-29-2018, 03:08 PM   #5
Macdaddy1
I went with speed engineering motor mounts and headers.
Macdaddy1 is offline   Reply With Quote
Old 07-30-2018, 12:28 PM   #6
Low Elco
Pontiac g8 gt worked great.
Low Elco is offline   Reply With Quote
Old 07-30-2018, 03:10 PM   #7
Wgesnerjr
Wgesnerjr's Avatar
I used a set from a 2010 Camaro. Fit great and looks stock.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 08-01-2018, 06:34 PM   #8
kipps
I assume you're installing an automatic. On the off-chance you're using an external hydraulic slave on a manual(maybe a mechanical clutch as well), you'll need a 98-02 f-body manifold on the driver's side. That's per my research. I don't have it fully assembled yet myself.
kipps is offline   Reply With Quote
Old 08-01-2018, 09:30 PM   #9
Clyde65
Clyde65's Avatar
Sanderson CSLS1
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
