Old 07-29-2018, 12:16 PM   #1
ratfreak8871
Speedo help please
79 c10 th400. have green 20tooth drive gear and white 36 tooth driven gear. 27in tire 3.73 rear. calculator says I need 54 tooth driven. every that sells them only go to 45 tooth. how hard is it to change the drive gear?
ratfreak8871 is offline   Reply With Quote
Old 07-29-2018, 02:13 PM   #2
geezer#99
geezer#99's Avatar
Re: Speedo help please
Changing the drive gear can be a lot of fun.
You gotta drop the driveshaft, tranny crossmember and remove the tailhousing of the tranny.
Then pull the gear, swap it out and put it all back togethor.
I’ve always cheated.
Bypassed all that work completely.
I use a ratio adaptor that fits onto your speedo cable.
Like here. They have calculators too.
https://transmissioncenter.net/?swoo...-gears&paged=1
Old 07-29-2018, 05:26 PM   #3
hatzie
Moderator
hatzie's Avatar
Ratio adapters wear out faster than plastic gears.
I dont trust the calculators either.
The GM tables are in the parts books. You need your tire size, axle ratio, and transmission gives you the correct gears.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-30-2018, 12:48 PM   #4
WilliamFd55
Not Sure if you are looking to stay 100% stock? I went with a GPS Speedo when I did an LS swap. Very easy, plug and play. Eliminates speedo cable and you wouldn't have to worry about tire size or gears. Just have to modify gauge cluster.
WilliamFd55 is offline   Reply With Quote
Old 07-30-2018, 07:05 PM   #5
Jake Wade
Jake Wade's Avatar
Now that is cool.
Jake Wade is offline   Reply With Quote
