Non A/C Heater Core
Hey Gang. I recently inherited my Dads 1968 GMC 2500 Series truck and while going through it to make it road worthy I found the heater core was leaking. After some searching on the web, it shows that the inner fender is required to come out to remove the heater/blower box. My truck is a non A/C truck and after looking around a bit at the truck I have my doubts if that is true. Has anyone else changed a heater core in a non A/C truck without removing body panels, or even worse, cutting open the heater box to get to the heater core?
![]() Join Date: Aug 2004
Re: Non A/C Heater Core
Welcome!
You can take out the inner fender or loosen the hood hinge and move it forward a bit. Maybe you can sneak the case out by pulling the blower motor first, but I've never done it that way. It's really pretty easy to take these trucks apart.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#4 | |
![]() Last edited by markizme; 07-31-2018 at 04:11 PM. Reason: Afterthought |
#5 | |
#7 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Hello Clay, thank you for your reply. The hood is already off of the truck as I am putting the final touches on installing a fresh motor in the truck, so removing the hood hinge is not a problem. I just don't want to get into something to further along the project than necessary at this point. I am waiting on a bit of exhaust hardware so after that I can drive this thing.
Hi Mark, My truck is a 1967 non a/c truck. When I changed my heater core, I did have to remove the inner fender, but it was worse thinking about it than actually doing it.
It was several years back but as I recall, I loosened the passenger hood hinge where it fastened to the inner fender and slid a 2x4 on top of the fender from the driver side fender to the top of the passenger side fender & supported the hood hinge. The inner fender bolts ran mainly just inside the wheel well and the other attachment points were pretty visible as I recall. Some of the inner fender bolts were a different length, so pay attention to that. It will save you a couple of minutes when you re-assemble it. Once the inner fender is loose, you can slide it down a couple of inches which gives you access to the heater core cover bolts. It’s pretty simple after that. Hope this helps. Last edited by Freddo; 07-31-2018 at 03:58 PM. Reason: Spelling |
![]() Join Date: Dec 2012
Dropping the fender and moving the hood hinge definitely helps - and makes getting everything reassembled (in my case) easier when dealing with the gasket/seal..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
That huge dent is probably there from the last time when you were a kid. That probably helped with removal.
Somebody pounded that fender down to remove the heater core once before.
If you reinstall with a new heater core, you can leave out that one bolt that is hard to get to for easier removal for the next owner.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#14 | |
Posted via Mobile Device |
