Equal opportunity joke ofender
![]() Join Date: Oct 2011
lowering blocks
I am upgrading my 68 panel to disc brakes. The new spindles have a 2" drop. I have been looking at the 2" lowering block for the rear trailing arms instead of lowering springs. Anyone have experience with the blocks or should I steer clear of them and use springs? I dont want it real low but I don't want a bad rake either
TIA Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
![]() Join Date: Feb 2016
Re: lowering blocks
I have had 2" blocks on my Blazer for over 100,000 miles with no issues. Blocks get you lower without loss of suspension travel which makes for a better ride. The only down side I know of is reduced ground clearance under the trailing arm or spring. Which for almost every pavement driven vehicle it is not an issue with 2 inch blocks. That being said 2" blocks and 35 series tires on 15" wheels might not be a good idea. But some measuring before hand should reveal any ground clearance problems.
Usually you have to replace the u-bolts that bolt the axle to the suspension. Just be sure to go with quality fasteners and you won't have problems. It is a good idea to check the nuts with a torque wrench periodically. Although I have never found a loose one it makes me feel better. Hope this helps Richard. Thanks again for the window seal!! ![]()
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
The Older Generation
Re: lowering blocks
I used 2" square tubing and made my own blocks on my White '67. It worked good. LockDoc
Re: lowering blocks
thanks guys. These are the ones I was looking at. They are billet and come with the u bolts for less than $90
Re: lowering blocks
I agree with all the above. I might add that you can probably make your own for less than $50 bucks and an hour of your time. A good spring shop should be able to bend up some quality U-bolts for $40 or less. A 2' long chunk of 2" tubing will be more than enough for a couple of blocks. Cut to length, drill 4 holes, a coat of paint and you are done.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
