11-15-2003, 04:00 AM | #1 |
Resistors for gauges different??
Are the resistors for the fuel gauge and the Temp gauge different values? My fuel gauge isn't working properly after I put my cluster back together after painting it and for some reason my temp gauge keeps pegging to hot also. Both gauges worked before I took cluster apart. If I got the resistors backwards would this happen.
Thanks!! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
11-15-2003, 04:42 AM | #2 |
Black 72 Chevy
It sounds like your temp guage is shorted.
11-15-2003, 04:44 AM | #3 |
hmmmmmm.... I'll check that out.
11-15-2003, 11:05 AM | #4 |
The resistors are different between temp and fuel. ?They can also be different between gauge clusters by year as I have seen several variations. My first truck had a bad resistor on the fuel gauge--drove me nuts trying to get it to work till I exchanged it with another one---fixed!!
11-15-2003, 03:55 PM | #5 |
Can someone tell me how to test these things with a digitsl multimeter? What values I should be looking for??? Thanks for everyones help!!!!
