Tranny Pan
My tranny pan has leaked for about a year now. I think it is warped or something. Any way I got a new summit cast alum. pan with drain and extra 2 quart capacity.
Any special way to do the swap or unbolt on and bolt the other? About how much tranny fluid will I need with extra 2 quarts after I drain it? Any special fluid? Thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Good time to change the filter too...What tranny you got in her? If it's a TH350 and you've only drained the pan, about 2-3 qts. If you drain the covertor about 7-8 qts. will be required. Add the extra 2 qts. for the deep pan, to the above quantities.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Right turn Clyde
Normal filter replacement takes about 3 quarts + the 2 for the pan is 6 so I would say 8 just to be sure. Total refill with convertor is about 10 but this doesn't say for swallow or deep pans so I assume its for the swallow.
Loosen all the bolts a little then starting in the back remove those bolt a couple at a time so the pan will tilt. Have drain pan under the pan, support the pan a little with your hand and let the fluid flow out. Make sure the front bolts are about 1/2-3/4s the way out but will not fall out. Be real careful in doing this or you will get a bath or a real big mess and if not so lucky both lol. I use normal fluid Dextron3 that's what it was designed to run with unless its getting some synthetic. Im not sure what's better in the synthetics. Aluminum doesn't bend it cracks so that something to thing about if you go off-roading in it. Could be pretty nasty if something smacked the transmission pan. When I first posted I had TH400 on my mind, Ive been messing with mine a lot. ![]()
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI Last edited by MylilBowTie; 11-15-2003 at 02:03 PM. |
