Old 11-15-2003, 08:46 PM   #1
rin68
rin68's Avatar
ride height with 2.5" drop??
So I finished the suspension rebuild/drop last night. When I put the truck back on the ground, it came out sitting way too low or so I think(pics below). Here's the specs: 2.5" CPP drop spindles, disc conversion, ECE stock? height front coils, everything else on the front end is relatively stock.
Anyway the drop seems too low, now when I pulled the old front coils out they were about 1.5-2" taller than the NEW "stock" height coils from ECE. I called ECE about this and they told me that someone had put different coils in my truck at some point in its life (which I know not to be true, I know every owner this truck has had) So against my better judgement I installed them and now the truck is sitting with the crossmember about 4" off the ground.
Is this the normal ride height for a 2.5" spindle drop??? I'll be calling ECE Monday morning to try to straighten this out
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 11-15-2003, 08:49 PM   #2
dinnut
dinnut's Avatar
that looks like more than a 2.5 drop to me. unless your 17" wheels and tires really take up a lot of the fenderwell
maybe they sent you the wrong springs.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-15-2003, 08:54 PM   #3
rin68
rin68's Avatar
i was thinking that, but ECE didn't seem to think that was possible. the wheel/tire combo is 255/50 17, 27" tall.
Old 11-15-2003, 09:14 PM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Looks perfect to me...actually I like them lower. Nice truck just the same. I have some stockers I will measure if you want to compare.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-15-2003, 11:02 PM   #5
c10crazy
Like a Rock!
c10crazy's Avatar
Man that looks awesome!. I love that stance.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 11-15-2003, 11:34 PM   #6
rin68
rin68's Avatar
it looks great yes, but i'm scared of it being too low. the headers have about 2.5" of clearance and the front crossmember is around 4". will i have problems with it this low??, this is a daily driver when the weather is nice. the other problem is the rear needs to be dropped farther to match the front stance, it currently at 4" and looks like it would need one more inch.
Old 11-15-2003, 11:51 PM   #7
72MARIO
72MARIO's Avatar
I bet that you got a 1 or 2 inch drop coil insted of the stocker. Looks good but the driverability is questionable... I would like to see it a bit higher if it was my driver.
Nice truck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-16-2003, 12:20 AM   #8
jugernot
Life, Be In It.....
jugernot's Avatar
I like the stance the way it is. I put 2.5 drop spindles and 1 inch drop springs on my front end. Unfortunatley the cab and front end are off, so I can't compare ride hieght with your. For me I think mine should be lower. I may go to air bags after the truck is finished.
jugernot is offline   Reply With Quote
Old 11-16-2003, 12:54 AM   #9
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
That looks like my 4" drop.... 2 1/2 spindles and 1 1/2 springs. I have 255/60/15's on the front and they are 26.7 tall. My truck doesn't look much lower if any at all.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 11-16-2003, 05:57 AM   #10
Hotrod70C10
Low & Slow
You won't have any problems if you are very careful. I have the same exact problem you do. I am going to install some chevelle shorty headers and ece's 6" drop springs, shock relocators, and super track bar. I know what you mean about the rear looking like it needs to go down another inch, Drive it around and see what you think, I personally haven't smacked anything on the ground yet and I've had the spindles in since July. Oh be prepared for a little bouncy ride with the rear sitting up that much higher also. That's one of the big reasons I am going to lower the rear more. Let us know what you decide!
4.5/6 drop
Old 11-16-2003, 07:34 AM   #11
ZOOMY
drop
That's about how mine looks with 2.5" ECE's in it. I have a set of Eibach's for the rear that dropped mine 5" if you want to trade for the 4" ECE's.......Zoomy
ZOOMY is offline   Reply With Quote
Old 11-16-2003, 01:58 PM   #12
cdowns
cdowns's Avatar
that looks about like mine does with dropped spindles and stock springs headman headers suck for a lowered truck i'm going to change mine to the chevelle ones in the spring
Old 11-17-2003, 04:10 AM   #13
Injected68LS1
Injected68LS1's Avatar
That's a great looking setup. I like the height and wheel/tire combo.
I'm ordering some wheels this next week. I really like that setup. I may now go with the 17s instead of the 18s.
Do you have any tire clearance problems? I'm installing some ECE drop spindles and their 2 inch drop springs. I'll be getting a similar looking wheel too.
Do you have a picture showing the whole side view of your truck?
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
