Question about removing seatbelts
I'm replacing my floor pans and want to take out the seat belts. These are bolted to the floor, no should harness. Can someone tell me the best way to loosen the bolt that bolts the seat belt to the floor? This has been on for 50 years and I don't know if its coming off at all?
I guess I can take a grinder to it? Thanks, Joe |
Re: Question about removing seatbelts
copious amounts of penatrant like mopar or pb blaster on both sides, bolt tails should be visible from the bottom..
if they're accessible with small die grinder, you can buzz around the bolts with wire wheel to break some rust off.. you can pull the plastic covers back on the inside and mask the webbing with plastic to prevent damage if they're salvageable.. if the bolts will budge, try tightening them just a skosh to break the rusted edge underneath, then back off slightly.. use hand tools so you can feel the movement.. repeat these small movements like working a tap so the threads have a chance to clear.. and keep them wet with penatrant.. if they have to be cut, dress the inside stud thats left so it will pass through and remove from the bottom with vise grips or tack weld a not onto it and wrench out, access permitting.. the cleaner thread inside will pass through more easily than dragging the corroded outside portion up through the top.. hope that helps or at least gives you some ideas, good luck!
I started out with nothing - and I still have most of it |
![]() Join Date: Apr 2016
I had 2 of those bolts that would not give by more than 1 or two turns. I ended up tightening them back down and using a dremel tool with a small cutting disc to clean the threads of the bolt from under the truck. It worked.
Soak them in PB Blaster or Sea Foam for a while before attempting to remove.
Clean the rust off the bottom side first so you are not trying to clean by brute force. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Roadtrip!
![]() Join Date: Feb 2003
All good advice. Soak them from the top and the bottom. Loosen a little bit, soak with penetrating oil, tighten. Repeat numerous times. An impact with 6 point socket will help. If it is a 67 with the narrow bolts, take your time. They round off easy.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Who Changed This?
![]() Join Date: Jan 2013
That six-point socket was going to be my recommendation, too. Anything to keep from stripping the heads off, and having to drill the buggers out.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I couldnt get mine off by hans so I took it my trucsted local body shop. They used an impact gun and I remember standing 40 feet away from the truck when they were taking the bolts out and the impact was screaming to loosen and get them out. From reading the posts here I its par for the course them being difficult to remove.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Great advice! Thank you
