08-16-2018, 10:02 PM | #1 |
Three squarebody questions
Did all of the 73-87 squares have the same thickness door glass?I have a real thin one that came from somewhere.
I noticed on both sides of my 85 the lower rear bed wheel well was loose at the bottom. How was they secured at the factory? Does all window sashes have a loose metal strip?I have 4 and they all have a loose strip.How to you repair it? |
08-16-2018, 11:52 PM | #2 |
Re: Three squarebody questions
The only one I can answer is that the rear wheel opening on the bed has a brace that stiffens it up. About 5/16" round stock with flattened ends with a bolt hole drilled in them. Yours is obviously missing.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
08-17-2018, 06:01 AM | #3 |
I have that round brace in front of the rear wheels.Are you sure there is supposed to be one on the rear behind tires?I got a couple more squares and they are secure without rod brace on rear.
08-17-2018, 06:29 AM | #4 |
I aint talking about wheel well trim being loose. If you grab the rear lower bedside behind the wheel well trim you can move it back and forth.
08-17-2018, 09:15 AM | #5 |
the newer windows are thinner don,t know which year, look under ordering window felts and it will tell which years
08-17-2018, 01:05 PM | #6 |
Yours appears to be missing the about 6"x6" metal piece that serves as a rear wheel well mud flap. It uses two bolts along the top and one of the holes you can see grass through in your pic. There was a thread a few weeks ago about those.
No clue on the window questions. |
08-17-2018, 08:19 PM | #7 |
Sorry for the wrong info on the support brace. Mine is on the front, not rear.
Here is a pic of mine. No movement on the outer sheet metal.
