Turn signals blinking fast
So I had a bad rear bulb, threw in a brand new 1157, and now turn signals are going fast. Threw a new one in the other side too, no change. Thinking I possibly got a bad bulb/bulbs since that was the only change, and they worked fine prior?
Re: Turn signals blinking fast
Yes, I've repeatedly had to change bulbs like your situation. Nowadays they are made like garbage, typical overseas, south of Texas junk. Check the front bulb, you might be surprised that it also zeked out
![]() Join Date: Feb 2016
The stock turn signal system's flash rate is determined by the resistance of the system. The flasher has a bimetallic strip inside that the current to the bulbs flows through. When energized, the strip heats up until it moves and breaks the circuit. Once the circuit is broken the strip cools moving to the original position where it reconnects the circuit making the bulb come on until the strip reheats then the bulb goes off again. The greater the current draw the faster the strip heats up and breaks the circuit. Which is why when trailer lights are added to a stock truck the signals go into hyper flash. More load equals more current equals more flashing.
Your new bulbs have greater current draw than your old ones did and the flasher is operating at a faster rate due to the increased current. The new bulbs are probably brighter than the old ones. Going to an electronic flasher should solve your problem. They are common, inexpensive, and the fix for trucks with trailers.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#4 | |
