08-19-2018, 04:50 PM | #1 |
70+ ( Old Skool Club )
Tilt Wheel Help
I am getting my original tilt reasdy to install in the truck and bought this new PRNDL indicator thing and it doesn't want to push in all the way. Is it whewre it it is supposed to be or should it go in more and do I have the right one.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-19-2018, 07:00 PM | #2 |
Re: Tilt Wheel Help
It looks to be all the way in. Does it move freely?
Often the white pointer is too thick, sand the sides down by rubbing the pointer on a piece of sandpaper which is on a flat surface to correct the thickness. Make sure to install the pointer correctly, the "hook" at the bottom of the pointer goes in between the indicator housing and the indicator lens...the "hook" keeps the pointer close to the lens and pushes or pulls the pointer out of the shift bowl groove. |
08-19-2018, 07:16 PM | #3 |
Moderator
Re: Tilt Wheel Help
Try tilting the mechanism in different locked positions when you install it. I’ve done that to assist installing a repro pointer and it helps to find the “sweet spot” where it will go in easy.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-19-2018, 07:21 PM | #4 |
Re: Tilt Wheel Help
Thanks for the help guys.
