Old 08-23-2018, 12:32 PM   #1
daverepair
Timken 221 transfer case: output shaft play?
I have a '60 K10, and while doing some maintenance(removing front driveshaft to replace a u-joint), discovered in & out play in the front output shaft, in the transfer case. I'm assuming this is not right(and not good). Can anyone confirm, there should be no play(movement) of the shaft? Am I looking at a rebuild, to correct this?
I have the shop manual, it does not show any shims on this shaft to adjust bearing preload. Anyone have experience with this problem? Thanks, Dave
daverepair is offline   Reply With Quote
Old 08-23-2018, 06:07 PM   #2
jeffahart
jeffahart's Avatar
Re: Timken 221 transfer case: output shaft play?
I would try to loosen the lock nut on the yoke and re-torque it. Just to see. Probably needs a rebuild. I just had my np205 and sm465 rebuilt. I installed them Saturday. When I read this, I walked to my garage and yanked on the rear output yoke through the open hump . NO in out play. Not sure it helps, but it would bug me too, were I you. In time one of the smarter tranny/transfer guys will chime in. Mines 205 Not a timkin, but probably the same or similar bearing setup.
j
White K20
jeffahart is offline   Reply With Quote
Old 08-24-2018, 11:51 AM   #3
dieseldude4bt
You should find what you need here.
http://www.persh.org/images/65Pickup/T221%5B1%5D.pdf
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 08-24-2018, 02:36 PM   #4
61K10
61K10's Avatar
Pull the rear cap off the input shaft and see if it's worn, also as Dd said about the yoke. any grinding noise other that t/f case wine?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
