![]() Join Date: Feb 2009
Is this rag joint coupler bad, and where to get a good replacement?
I was rebuilding my rag joint when I noticed the inside of the original coupler may be worn. My first thought was yeah it's toast, but I'm not so sure. Seems the shaft on the steering box would show more wear. Can anyone confirm?
Quality replacement rag joints anyone? At a glance they look to run $25-$70ish. Thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Is this rag joint coupler bad, and where to get a good replacement?
The flat spot on the steering shaft and the smooth part on the coupler line up. The parts shown look to be in decent shape to me.
#3 | |
Strikes me odd the manufacturer would build a coupler with fewer splines than the shaft, but then I have nothing to compare it to, and kinda green anyhow.
#4 | |
If the area between the arrows is the only part on the rag joint that has splines, then you are probably missing some splines due to wear. My rag joint was about 70% spline and 30% flat area. |
Its a Truck Thing......
Lares Part Number 200 or 201 depending on the size of the shaft. I get them from RockAuto, They are made in USA and very good quality. Less than $20 + shipping.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Who Changed This?
![]() Join Date: Jan 2013
It doesn't slide. Once those splines are properly engaged, that shaft isn't going to lose registration on the clamping part, end of story. And I live in southern California, where we won't buy a vehicle if there is a bubble anywhere in the paint.
clean it up with a small wire brush.
Thanks for all the info. I'm not convinced the old one is bad, but just in case, I'll order the Lares part.
#9 | |
Smitty
