11-17-2003, 01:09 AM | #1 |
its all about the +6 inches
I should know the answer to this one...(Dist Q)
Small block chevy...which way would advance the timing?
11-17-2003, 01:29 AM | #2 |
Counterclock wise.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
11-17-2003, 01:30 AM | #3 |
P.S. Do you own a tire store?
11-17-2003, 01:32 AM | #4 |
Watch out for your cornhole !
All normal GM distributors, look at it from the top, whatever way the vac hose nipple is pointing is the direction you turn it to advance.
11-17-2003, 01:40 AM | #5 |
advance
CCW looking at it from the top. Turning the cap opposite the rotor rotation advances it.......Zoomy
11-17-2003, 01:42 AM | #6 |
Thanks guys.
A tire store? Why do you ask? No..I hardly own the tires I need...let alone a store to keep them in. |
11-17-2003, 01:46 AM | #7 |
Just that everytime I see your avatar the smoke is still rolling.lol
11-17-2003, 01:52 AM | #8 |
LOL!
11-17-2003, 04:16 AM | #9 |
if you can't ever remember when you need to like me, then with it running which ever way speeds up the idle is advacing it
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
11-17-2003, 10:26 AM | #10 |
Tire store??? Proctologist!!!
If you ever saw the tires on Andy's truck you would never have asked that question!!!!!!!!!!
I think Andy is a proctologist after see his recent post reply about resting a $dollar bill against his "exhaust pipe" to see the "movement" ie. if a valve is bad the bill will pop or get sucked back against the pipe!!!!!!!!!!!!! hehehehehe |
11-18-2003, 01:10 AM | #11 |
LOL. Huck, you didn't notice that my front tires are actually brand new! Not junk yard new...fresh from Jegs.
Although, the right rear does seem to have less tread than the rest. Next time you burn an exhaust valve...try the 'ole dollar bill test. It'll suprise you. |
