09-11-2018, 04:56 PM | #1 |
Need some advice on chevy buyin’
Thanks for stopping by my post, I’m a 16 year old looking to buy a squarebody for my first. From working on a farm and doing landscaping, I’ve made about $4800. I’ve found a 69 C20 Longhorn about 3 hours out from where I live, so if I go down to take a look, I wanna be sure I have the knowledge to make the right call and have an idea of what I’m getting myself into. I guess I’m trying to put together a checklist/ buyers guide.
Here is a link to the truck page: https://bend.craigslist.org/cto/d/19...690085385.html If you’ve got any spare time, I’d really appreciate all the chevy wisdom I can get. If you know any other 2 tone (preferably a brighter color scheme) for around $2500 or less, I’d also love to see. Thank you, have a nice day |
09-11-2018, 06:53 PM | #2 |
Re: Need some advice on chevy buyin’
Bend is a great place to get a rust-free truck! Longhorns are popular in the fact that I believe they didn't make many of them. Take the 3 hour drive!
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
09-11-2018, 06:54 PM | #3 |
It also seems like a rare color combo; orange with saddle interior.
09-11-2018, 07:02 PM | #4 |
09-11-2018, 09:14 PM | #5 |
Hard to tell by the pictures but doesn’t look like a bad truck. Look around that windshield for rust. Also look underneath at cab corners, supports, etc. Look for any shoty work. I would plan on relocating that fuel tank and putting shoulder harnesses in your budget. Those are key safety mods in modern day roads. Should make a great first truck.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
09-11-2018, 09:57 PM | #6 |
That looks like a nice truck. Get under it, inside and on top to look for rust also an extra set of eyes are sometimes helpful but for a 3 hour drive I would be asking for those areas in pictures first.
If you are looking for a Squarebody why not wait for one. If you can't find one there, head north. Good luck. |
09-11-2018, 11:08 PM | #7 | |
Be sure to start the engine stone cold (beware of sellers who warm the vehicle up for you). Then get it nice and hot and restart the truck. This will help detect common carburetor issues. Look for wiring that has been cut and patched with lots of crimp connectors. Especially under the dash. Inspect the fuse block for corrosion. Check the color of the engine oil, transmission fluid, brake fluid, power steering fluid, and if possible the rear end lube. If your not sure how to check these YouTube will be helpful. If you have a voltmeter check the voltage before starting and RPM both running at idle and about 2000 RPM to see if the charging system is operating as it should be. Loud clunks and rattles going over bumps are a sign that the suspension is worn. The truck should stop straight under firm braking. The transmission should shift smoothly and not pause or delay on gear changes. If possible coast down a hill at 40-50 mph and listen for rattles or vibrations that weren't there while cruising. Plan on replacing the alternator, water pump, master and wheel cylinders soon after purchasing if the truck has sat for couple of years or more. These are likely to fail. I'm sure that others will chime in. There is a lot to cover especially if it is your first truck. I recommend making a check off sheet to refer to once your looking at the truck. And when you get there actually look at it. Don't be afraid to ask questions and doubt what you may be told. If possible I find that sleeping on the decision to buy can keep from getting caught up in moment. These trucks are fairly common to find around these parts. So there is no need to buy the first one you see. Luckily for you there are some good local sources for new and used parts as well as the internet. Longhorns are not very common as they were only built for a short period. That doesn't necessarily make them worth more but they are truly cool to some of us. Good luck!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 09-11-2018 at 11:15 PM. |
09-14-2018, 12:14 PM | #8 |
Thanks to all who took the time and replied! replied!
09-14-2018, 09:24 PM | #9 |
Your welcome. I'm sure you would get a larger response if you posted the question in the pick up section. The things to check would be the same for a pick up as a Suburban outside of the sheet metal parts aft of the windshield. Then for the most part rust would be the concern to look for.
Good luck with your search.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-19-2018, 11:27 PM | #10 |
Good luck bud... and you made the right choice... BUT a "squarebody is actually 73-87/91 not sure what nickname is for a 67-72 ... even though I have built Chevys my entire life and a ton of SQUAREs... this is my first venture into 67-72s... Good luck and DONT get into a rush!
Steve |
Tags |
buying, chevy, question |
