trans cooling lines ???
im needing to replace trans cooling lines , considering stainless but reviews are not to favorable. Any recommendations thanks for your input.
Re: trans cooling lines ???
I went with copper as it was only a couple bucks more than the steel. I bent it by hand and it should help with cooling a little better than steel. Local oreillys has a bunch hanging in the store. I did each run with one stick so I don't have any couplings or anything.
#3 | |
The Older Generation
Buy some NiCopp tubing on E-bay in whatever size your trans uses and bend your own. Bends easy, flares easy, and won't rust. LockDoc
bought mine at jegs. perfect fit. made from aluminum. easy to tweak
![]() Join Date: Jul 2015
Like lockDoc said, NiCopp tubing is super easy to work with, flairs easy, wont rust, and looks great. SS can be a real pain in the shorts to work with and even harder to flair. My local auto parts store has it in 25 foot roll for reasonable pricing if you are in need of some ASAP check there.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
