09-19-2018, 09:14 PM | #1 |
Is there a thread or list for a complete hydroboost with captainfab stuff?
Don’t really see a thread with a complete list of parts need to retrofit a hydroboost from an Astro Van or a newer 2500hd.
As far as I can tell I need captain fabs brackets (I think there are two?) A hydroboost from a 97 astrovan A master cylinder and reservoir (forgive me if I’m ignorant about how these work together and or the terminology) A proportioning valve for front disks and rear drums, All the fittings and hoses (from what I can tell there may be ss an 6 hose and fittings I might be able to piece together?) going to the stock ps pump in a truck lq4 ls Just curious if someone else had done this exact conversion and would point me to the thread or offer a few pointer on part numbers of where to source stuff. |
09-20-2018, 12:30 AM | #2 | |
All about them K’s
Re: Is there a thread or list for a complete hydroboost with captainfab stuff?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 09-20-2018 at 12:43 AM. |
09-21-2018, 09:11 PM | #3 |
I took parts from a 2001 2500 hd and noticed that the thread in fitting in the back of the hydroboost organ donor truck had a bigger hole, and obviously the truck reservoir tank had one more return fitting. I've read where you can "TEE" the returns together and use the single return fitting on the reservoir tank. I did happen to use the fitting, spool and spring from inside the pump body. Good luck.
09-22-2018, 12:07 AM | #4 |
The Older Generation
Don't know if you have seen this thread or not. http://67-72chevytrucks.com/vboard/s...d.php?t=523502 I have not read it but it might help you. LockDoc
