Old 09-21-2018, 08:09 PM   #1
Caminuvik
Detroit locker
I ended up with a 77 blazer, I was told that it had a Detroit locker. Another person said that they did not make a Detroit locker for a GM 12 bolt. Does anyone know which is correct. I am more into 3/4, 1 tons than halves, Thanks
Caminuvik is offline   Reply With Quote
Old 09-21-2018, 08:29 PM   #2
mikebte
Re: Detroit locker
Prolly referring the the G80, it’s a Detroit locker. I think in 77 it was optional. GM really pushed this and still uses it today. Most older rear ends I have seen with the G80 have been broken and all the teeth are missing or in the bottom of the housing. But older trucks saw more farm use then modern trucks. Best to remove the cover and have a look see.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 09-21-2018, 09:31 PM   #3
mongocanfly
mongocanfly's Avatar
Re: Detroit locker
My bad...I didn't even see the pic was wrong until you pointed it out k30...my network is running really slow for some unknown reason and i didnt see it was wrong...so I deleted it...
But yeah....pull the cover...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-21-2018, 10:18 PM   #4
sweetk30
sweetk30's Avatar
Re: Detroit locker
mine a bit slow tonight also .
figure i would just clear it up if you missed it .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-21-2018, 10:21 PM   #5
Caminuvik
Re: Detroit locker
Well guess I will pull dif cover during a hopefully break in the rain tomorrow. 🤐 Now if i understand there could be a true locker in there, -they are made?
Old 09-21-2018, 10:30 PM   #6
Matt Man
Matt Man's Avatar
Re: Detroit locker
They do make detroit lockers for the gm 12 bolt truck rear end. Is the truck in running condition? If it is you can google driving characteristics of the detroit locker, they make there presence pretty easily with the clunk when you let off the accelerator. My 81 has one installed in the 12 bolt.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 09-21-2018, 10:43 PM   #7
Caminuvik
Re: Detroit locker
No, not running, but time, money, parts, and knowledge it could be, unfortunately I have little of those. Going to have to learn to post pictures, unsuccessful attempts so far.
Old 09-21-2018, 11:14 PM   #8
mongocanfly
Re: Detroit locker
Here's how to post pics....http://67-72chevytrucks.com/vboard/s...sting+pictures
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-21-2018, 11:14 PM   #9
mikebte
Re: Detroit locker
Here is what it may look like if it has the G80.
Old 09-21-2018, 11:52 PM   #10
Caminuvik
Re: Detroit locker
Great picture - will look tomorrow even if it snows. I was doing ok with the picture posting, but got the "security token missing" the thread stated that was a too large of picture. Now, I need to figure out how to reduce size of a picture in my Gallery. Just never seems to end. 😂 Thanks
Old 09-22-2018, 11:37 AM   #11
Caminuvik
Re: Detroit locker
Picture of the Blazer diff.
Feel good as I have successfully uploaded a picture. Could someone tell me what it is and what I need to use to replace the diff oil. Thanks
Old 09-22-2018, 12:00 PM   #12
mongocanfly
Re: Detroit locker
Looks like a open diff....can you get a better pic of the center of the diff where the spider and side gears are?
This area
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-22-2018, 12:14 PM   #13
mongocanfly
Re: Detroit locker
I can't tell what these are outlined in red
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-22-2018, 12:51 PM   #14
Caminuvik
Re: Detroit locker
A better picture, I think.
Old 09-22-2018, 12:58 PM   #15
Caminuvik
Re: Detroit locker
Old 09-22-2018, 02:28 PM   #16
mongocanfly
Re: Detroit locker
Spin the diff over and get a pic of the opposite side of the carrier...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-22-2018, 04:11 PM   #17
Caminuvik
Re: Detroit locker
opposite side
Old 09-22-2018, 04:15 PM   #18
mikebte
Re: Detroit locker
I us delo that I can pick up at truck shops cheap, but I think they have it at auto parts stores as well. Service intervols on delo is way higher than most others. Or at least that's what it says on the bottle. And being the trucking industry the oils get a lot of testing and research.
Sorry, many years in the trucking industry. I even run Alison Transmission fluid in my GM truck.
Old 09-22-2018, 04:57 PM   #19
Killer Bee
Killer Bee's Avatar
Re: Detroit locker
good pictures, sure looks like a G80 Gov-Lock [governor locker] or affectionately called Gov-Bomb
lots of good illustrations and videos out there on these.. and as mentioned, they are not the same as a Detroit Locker..
I wouldn't just willy-nilly pour TES-295 in my automotive trans without checking specs..
modern automotive ATF has gotten real slippery with non backwards compatibility.. <-- pun intended
as for differentials, same issues arise, better to check specs of any oils you're planning to use..
must consider weights, friction modifiers, soft parts compatibility e.g. seals, gaskets, clutches, sensor wiring, etc..
'high performance' for some applications may = 'no performance' for others..
good luck y'all!
Old 09-22-2018, 05:03 PM   #20
Caminuvik
Re: Detroit locker
I thought so also, but noticed an extra bar in the Blazer one, and in the picture of G80 on the right is that a clutch pack? Doesn't seem to be one in the Blazer diff. Could this just be an open diff?
Old 09-22-2018, 05:21 PM   #21
Killer Bee
Killer Bee's Avatar
Re: Detroit locker
lol, I edited my post after noticing something a little different there.. oops
that deserves closer inspection and/or comparisons to known stock units..
I know little more about these than what they generally look like and how they work..
other members above are much better candidates to answer that question..
good luck!
Old 09-23-2018, 03:38 PM   #22
mikebte
Smile Re: Detroit locker
I completely understand your concern and I verified that TES had superior specs compared to and Dextron available, as for the Deli, it is also a good oil.
For sure a gov bomb. I run delo on my G80 with good results. If you feel better the auto parts store can give you the correct fluid needed. Fluid research can be a fine line, but nothing I own has warranty, sI I run what make's it last longer.
Originally Posted by Caminuvik View Post
Thanks, it been a great learning experience. I will drag it up and park it, thought it was going to be a bonus.
Love the blazer, looks like a good project
My YouTube:
Old 09-23-2018, 04:39 PM   #23
Killer Bee
Killer Bee's Avatar
Re: Detroit locker
I get your point but you're assumptions aren't fact based and could end up wrecking a drivetrain component because of brand loyalty..
I've been servicing and repairing heavy junk for 30ish years, longer if you include maintaining ag machines on family farm..
I currently supervise 12 mechanics and manage maintenance and repair of approx. 800 pieces of equip. including cranes, utility, earth moving, material handling, class 1-9 trucks, etc.
I get it, completely get it.. but you must verify the machine specs for every compartment before adding/replacing any fluids..
if your formula works for you, great.. but it's not necessarily the best advice across the board..
off my soap box, good luck y'all!
Old 09-23-2018, 07:06 PM   #24
Caminuvik
Re: Detroit locker
Never thought too much of the diff fluid, I would heed the advice given if I was going to use this diff. My goal or need is a truck for my snow plow and the blazer is unfortunately not the answer so I will park it. As I now need diff fluid could I just put some 80-90 in it to tow it up and leave it?
Here is a picture of the plow on the truck that is being replaced.
Any idea why pictures are sideways? Thanks
Old 09-22-2018, 06:17 PM   #25
mongocanfly
Re: Detroit locker
Yep its a g80..govlok...youll need the correct lube for it....https://www.chevytalk.org/fusionbb/s...php?tid/256237
Mongo...aka Greg
RIP Dad
RIP Jesse
