Old 09-25-2018, 12:24 PM   #1
The1960APE
The1960APE's Avatar
swapping a 1991 blazer grill to a 85 truck
I picked up a nice 85 at the Pigeon Forge Rod runs last week, I would like to swap it over to the 91 Blazer grill! I found this tech article which proved to be of great help!
https://ck5.com/forums/resources/89-...rille-swap.19/
I found all the parts on LMC to do the swap except for the wiring, I've been told if you can find the blazer harness that plugs into the firewall you can just do a plug and unplug from the truck harness to the blazer harness, (not sure?) and I've been told you need pigtails and splice! I am not really sure what I need to do this, can anyone advise?
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 09-30-2018, 10:43 AM   #2
duallydude63
Re: swapping a 1991 blazer grill to a 85 truck
U can also check suburban / crewcab from 91 they are still square body !!
duallydude63 is offline   Reply With Quote
Old 09-30-2018, 02:24 PM   #3
sweetk30
sweetk30's Avatar
dont forget the most overlooked other vehicle for the center grill and pig tails for wiring . . . . g-series vans with the same front clip .
and this site member is down south selling a whole front gm clip . http://67-72chevytrucks.com/vboard/s...d.php?t=771543
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 09-30-2018, 04:55 PM   #4
gmachinz
I have NEW 88-91 conversion harnesses for it. PM me for more info!
gmachinz is offline   Reply With Quote
Old 10-01-2018, 10:26 PM   #5
Wwes
You'll also need a new core support. I have one id let go for cheap, and will be in NC in two weeks could meet you somewhere. I considered doing this swap but changed my mind.
Wwes is offline   Reply With Quote
