But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Front Trailer Hitch Ideas
I found this in another thread.
I want to do something similar to my 66 C20. Anybody have other ideas?
Re: Front Trailer Hitch Ideas
the above looks good, only thing I would change is widen the attachment to the top of the rail as well, boxing the frame completely..
the overhanging load pull on that would tend to twist depending on intended use.. typical rear receivers attach at two or three points 12"-18" down the frame to overcome that torsion.. in the front, spring hangers or other suspension components may not make that feasible.. I build things like that strong enough to hang the truck from it.. ya' know, just in case you need to hang the truck from it ![]() adjust height to clear lower edge of bumper when installed and adjust depth considering the length of the drawbars you have.. good luck!
I started out with nothing - and I still have most of it |
Thanks,
I'm not going to use it for anything but moving things around on my property. Years ago I had one that simply hooked over the front bumper.
