Old 10-01-2018, 12:20 PM   #1
blackhawck
Wheel Vintiques 6 lug
Has anyone tried the WV wheels on a K-10? They are now showing a 15x8 6x5.5 wheel. Do they take the dog dish caps, is the backspacing correct for discs? I have been scouring CL and junkyards for over a year and haven't located a set but would pop for these if they take the caps.
blackhawck is offline   Reply With Quote
Old 10-01-2018, 12:40 PM   #2
rsavage
rsavage's Avatar
Re: Wheel Vintiques 6 lug
I bought a set but have only test-fitted them on my '69 K5 Blazer which has drum brakes so I can't help you on the disc brake clearance. They do take hub caps. The back space puts the inside edge of the wheel almost up against the tie rod end. I haven't adjusted the toe in so maybe that will eliminate the interference issue. If not I will use 1/4" spacers and some longer lugs. Back is fine. Blazer is getting close to returning home so I can start putting it back together. O/S body work done, two coats of polyester primer and one coat of high build.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-01-2018, 12:45 PM   #3
blackhawck
Thanks, rsavage. Post some pics when you get them on, the blazer is looking good. Are they powder coated grey or white?
Old 10-01-2018, 02:13 PM   #4
cleszkie
cleszkie's Avatar
Not answering your specific question. But I have the WV 8-lug 16x8 rims on my Blazer. Correct backspacing, and the stock 3/4 ton dog dish caps go right on. I should note that when I bough my set, WV no longer offered white powder coat finish. All they sold was black satin powder coat or chrome finishes.
cleszkie is offline   Reply With Quote
