74, 08 5.3 swap. Oil pan hitting center link
I finished this truck up in 2012 and had an alignment done. That alignment has never been right and I basically let the truck sit. I get motivated again last week and started back in on it. I had an alignment appointment today and the tech tells me I have the center link on upside down. When he puts in the correct way, it hits the oil pan. Any suggestions on get the engine up high enough to mis it? I cant recall what mounts I bought either.
1996 S-10, 17" Boyd Coddington smoothie II, lowered 5/5, 98 up front, grant step shavers, maserati deep emerald green 2002 Camaro SS, LS-1 motorsports lid, Eibach spring, Chrome ZR-1s 9/11, TEA heads, forged internals, 244/248 cam, 3400 stall, full bmr suspension, TNT F2 kit, BLA BLA BLA ![]() 74 C-10, lsx swap, bonspeed billets, full frame off build 2008 Avalanche LTZ all stock |
![]() ![]() Join Date: May 2015
Re: 74, 08 5.3 swap. Oil pan hitting center link
Any pics?...I used eBay mount adapter plates and stock sb mounts...I have no issues with clearance..using the truck pan....
I haven't had a chance to get under it and investigate. I just thought it may be a common thing so I'd ask the question prior to digging into it. This site helped me tremendously when I was doing the swap but I have forgotten so much about it. I'll revisit this when I have had time to check it out.
Garage wrench
I almost had this issue with my Suburban. What I found is that my passenger side motor mount had broken. t was a cheap $11 parts store rubber mount. I noticed the engine sitting off and down and that was the culprit. I've since replaced the stock rubber mounts with energy suspension poly mounts so it's all good now. This may be an area for you to look into....
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Had the same issue from PO installed 5.3 swap. When I redid the whole front suspension I had to take a grinder to it to get proper clearance. Swap was done using stock mounts. You can always get some DD sliders and alleviate that problem asap but moving the engine back some.
#6 | |
I know 4 different guys with LS swapped square-bodies and they all used these mounts with no issues. I actually used the same ones on my '60 with torsion bar front suspension and F-body oil pan. No issues with mine either. https://www.ebay.com/itm/1973-1987-C...ty!39701!US!-1 |
Thanks for the replies guys. I dont think a different mount is going to be the best solution unless it will maintain my engine location now. Everything is and has been complete since 2012, meaning the custom driveshaft, fuel lines, transmission, etc would have to be changed. I'm hoping I can just space it up a bit.
Also SBTork has a valid point that i'm going to investigate, the motor mounts. Ive driven the truck about 600 miles and more of those has been beating on it than not. Do any of you have any pics of your center link to oil pan clearance? Also, the proper way it should be oriented? The truck is an 08 5.3 with all truck accessories and oil pan. Here are a few pics of the engine bay... Thanks again
1996 S-10, 17" Boyd Coddington smoothie II, lowered 5/5, 98 up front, grant step shavers, maserati deep emerald green 2002 Camaro SS, LS-1 motorsports lid, Eibach spring, Chrome ZR-1s 9/11, TEA heads, forged internals, 244/248 cam, 3400 stall, full bmr suspension, TNT F2 kit, BLA BLA BLA ![]() 74 C-10, lsx swap, bonspeed billets, full frame off build 2008 Avalanche LTZ all stock Last edited by pwtr02ss; 10-02-2018 at 12:22 PM. |
![]() Join Date: Jun 2016
Man that black paint is "deep"
Looks good. Bubba |
Alright, I flipped it around and sure enough, it’s hitting. I don’t think the motor mounts are broken, I jacked ont he oil pan and nothing moved but the truck. I have attached pics of the mounts. Anyone know if DD mounts or others are slightly taller but would also allow engine placement to remain the same? As you can see, from plate to bolt center is 2”. It’s the same on both sides
Garage wrench
I have a set of DD mounts that I just painted, once I get home from work I'll take a pic with a tape measure like you did with yours and we will know for sure. Just looking at it sitting in the engine bay it does look like it's sitting a little low but not crazy low. But, just looking at that picture of your mounts I think the DD mounts set the engine up higher, but I'll get that picture and we will know for sure.
I could take a pic of my center link/front of oil pan area but it wouldn't do much good. I am running a GM Performance Parts muscle car LS pan on mine, part number 19212593. And I believe the GMPP oil pan is slightly lower profile at the front of the engine versus the truck pan.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 10-06-2018 at 01:19 PM. Reason: forgot things |
Thanks! I got some engine plates that I think I can use as a spacer. They are about 1/4” thick. I will report back after I get the motivation to crawl under there and attempt the dreadful task.
Well after 4 hours of cursing whoever built these god forsaken mounts, I finally got the plates in and everything bolted back together. Still hitting enough to make the steering stiff. SBtork, did you have a chance to measure those did mounts? I think they need to be at least 2.5” to center of the bolt for it to work. Idk why I have luck like this sometimes.....
