10-07-2018, 02:56 PM | #1 |
Drive shaft cut
I found a truck I like and it already has an LS engine mounted but still requires more work. Driveshaft also needs to be cut. Is it hard finding a place that can cut a driveshaft?
10-07-2018, 03:39 PM | #2 |
Re: Drive shaft cut
I think you would look up on google or yellow pages if you still have one, drive shaft balancing. There are drive shaft shops. If you are close to Princeton TX there is a drive shaft shop right there on US 380/University Dr. Also Eagle Transmission advertises they shorten and balance drive shafts. That is who I had rebuild my transmission.
10-07-2018, 03:41 PM | #3 | |
Re: Drive shaft cut
10-07-2018, 04:57 PM | #4 |
Re: Drive shaft cut
Do you have an Inland Trucks Co? They have done mine.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
10-07-2018, 08:12 PM | #5 |
Re: Drive shaft cut
I've done several of my own.
Not that difficult
10-07-2018, 10:14 PM | #6 |
Re: Drive shaft cut
About any reputable semi-truck shop can do it
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
10-07-2018, 10:29 PM | #7 |
Re: Drive shaft cut
Don't know your model but my installer found a late model Chevy car shaft that fit with no cutting on my 70 C10.
10-08-2018, 01:42 PM | #8 |
motor exploder
Re: Drive shaft cut
Anyone can cut it, the hard part is welding the yoke back on straight and balancing it ! I've had good experiences using heavy duty/semi-truck shops for this type of thing. What part of Texas are you in? That may help us out a little. I lived in Dallas for a long time before moving to AR, lots of good shops around there.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
