Old 10-07-2018, 05:04 PM   #1
forestb
forestb's Avatar
Wheel spacers
I would like to space out my rear tires about 1/8 of an inch so that my tires don’t rub on the inside of wheel wells. Would it be possible to use washers on each lug or should I look for a 1/8 inch wheel spacer? It only rubs when turning into driveways so I figure it is barely rubbing
forestb is offline   Reply With Quote
Old 10-07-2018, 05:51 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Wheel spacers
I'd go with the spacer and not the washers. Spreads pressure out instead of in little spots.
Old 10-09-2018, 04:16 PM   #3
forestb
forestb's Avatar
Re: Wheel spacers
So I can only find 1/4 inch and thicker 6X5.5 lug spacers. What are my options other than milling down the a 1/4 inch spacer to 1/8 inch.
Old 10-09-2018, 05:25 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Wheel spacers
1/8 plate. Drill holes using an old wheel as a template.
Old 10-09-2018, 05:38 PM   #5
forestb
forestb's Avatar
Re: Wheel spacers
I was thinking that also but I don't know how I would cut the outer diameter.
Old 10-09-2018, 05:58 PM   #6
geezer#99
geezer#99's Avatar
Re: Wheel spacers
Jigsaw works.
That’s what I used to make this oval air cleaner.
Old 10-09-2018, 06:07 PM   #7
forestb
forestb's Avatar
Re: Wheel spacers
What material should I use? I think the 1/4 in spacer that I have is aluminum.
Old 10-09-2018, 06:41 PM   #8
geezer#99
geezer#99's Avatar
Re: Wheel spacers
Use aluminum.
Metal supermarkets should have sheets of it.
Sometimes you can find some in the hardware store.
Old 10-09-2018, 06:44 PM   #9
aerotruk63
aerotruk63's Avatar
Re: Wheel spacers
Aluminum would be great. You can use wood working blades on a jigsaw to cut. General rule of thumb 3 teeth touching metal at all times. Lubricate while cutting or drilling. Milk or cream was a household solution. Holesaw for center bore , can be larger than wheel bore it doesn't matter. Save the wheel by cutting down an old drill bit to scribe stud hole centers then come back with a 1/2" if you have stock studs. The oversize holes will allow a little play. Paint can could be a close diameter for drawing circle or steal the kids compass for more refined results with a starting center point.
Old 10-09-2018, 06:48 PM   #10
forestb
forestb's Avatar
Re: Wheel spacers
thanks I will give it a try.
Old 10-09-2018, 07:12 PM   #11
jayoldschool
Moderator
Re: Wheel spacers
You check ebay? I got 3mm spacers on there, 6061 billet.
jayoldschool is offline   Reply With Quote
Old 10-09-2018, 09:09 PM   #12
Robert Haas
Re: Wheel spacers
A proper wheel mount should use a combination of sheer and capture around the axle that protrudes out of the drum. If you are building a spacer that moves the wheel load to just sheer on the studs you could have some issues. Also a proper wheel spacer is balanced.
Robert Haas is offline   Reply With Quote
