Old 10-08-2018, 12:33 PM   #1
ZEKE68
ZEKE68's Avatar
Two 4 inch spearkers for dash?
I am planning to install two 4 inch speakers under the dash to replace the dual voice coil 4 by 10 in there now. Anyone else tried this? I have door speakers to provide base.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 10-08-2018, 01:07 PM   #2
demian5
demian5's Avatar
Re: Two 4 inch spearkers for dash?
I did that on my 64 impala I installed 2- 4" infinity cappa speakers on a 1/2 plywood base and wrapped in black fabric.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-08-2018, 02:43 PM   #3
Problems
Problems's Avatar
Re: Two 4 inch spearkers for dash?l
I just did this on my Dad’s ‘70 442 convertible. I fabbed a plate up with 20 gauge steel painted it black, mounted in 2 kicker 43dsc44’s and mounted it in place of the factory single speaker. It sounds way better than a single replacement speaker but not great.
It wouldn’t be any harder for our trucks. In my truck I am doing 6.5s in the kick panels, because you can only expect so much sound out of 4in speakers.
Problems is offline   Reply With Quote
Old 10-08-2018, 02:57 PM   #4
ZEKE68
ZEKE68's Avatar
2 kicker 43dsc44’s, Those are the same speakers I bought to do mine. Hope they are louder than the dual coil speaker. My truck has 6 by 9 's in the door panels, I am going to use for woofers.
Old 10-08-2018, 04:59 PM   #5
ElKotze
ElKotze's Avatar
I used 2 5inch Alpines for the dash, had to fab a frame, pretty easy, and a powered 8inch woofer under the seats. Sounds nice.
'64 C10 LWB, 283, 5speed
'68 C20 LWB, 327, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super, 396, TH400
'66 C60, 292, 4speed
ElKotze is offline   Reply With Quote
Old 10-08-2018, 05:59 PM   #6
DA71Grande
DA71Grande's Avatar
I squeezed in a pair of Polk Audio MM461P under the dash still deciding if I want to add speakers to the doors or kick panel with a sub under the seat.
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 10-08-2018, 10:44 PM   #7
HO455
HO455's Avatar
I used a pair of 3" x6" speakers in my Burban. I liked they way they had more cone area lined up with the speaker slots than a pair of 4" speakers.
RIP Bob Parks.
Old 10-08-2018, 10:47 PM   #8
darrellyates
There are several threads on this in the audio section of this website. Do a search there. They show how to make mounting plates, attach, wire... Everything.
darrellyates is offline   Reply With Quote
Old 10-09-2018, 06:26 AM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Two 4 inch spearkers for dash?
Here is a link several of us have installed speakers and show what we did.
http://67-72chevytrucks.com/vboard/s...d.php?t=607314
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-09-2018, 06:49 AM   #10
I got lucky and found a pair of '67 rust free doors in excellent shape no one else wanted because they had 6x9 ovals cut in the door.... for cheap! Saved me from having to ruin perfectly good doors Hey, if GM offered a stereo system that's where they would have put them.
I also bought a pair of '72 scroll door panels someone had installed 6 1/2s in for next to nothing...with speakers for dirt cheap. I'll just set my originals off to the side for if and when being purely original matters. I like good sounding music.
I'll probably just go 3-way, but if I go component the speakers in dash would be a good idea. I had a nice '72 door for sale at a swap meet with one rust spot in the lower rear corner (for cheap). Guys would look at the inside and say if it wasn't for the speaker hole they would have taken it. I don't get that. No worries over the rust repair required but curse that bedeviled speaker hole that would be so much easier to repair. Holes on the dash would be easy to fix... on a restoration.
Old 10-09-2018, 07:25 AM   #11
Andy4639
Old member
Andy4639's Avatar
Talking Re: Two 4 inch spearkers for dash?
Cut them doors and lower them trucks and put late model engines in them but you better not cut that dash man! If you do you just killed that truck!
Old 10-09-2018, 09:01 AM   #12
rpmerf
rpmerf's Avatar
I have 2 x 4" speakers in place of the factory 4 x 10. I used a piece of plywood for the base. Used some stick on weather stripping around the edge so I could press it up against the dash. I used the bracket from the original speaker to hold it in place. I think the mounting is still kind of rigged, more balanced in place with zip ties.
It's being powered by a 70's tape deck I got at a swap meet for $5.
I am really happy with how it sounds. By no means great, but it works, gets decently loud, has some bass to it. Best off all, I built it out of spare parts, and didn't have to destroy any factory parts to get it installed.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-09-2018, 03:51 PM   #13
demian5
demian5's Avatar
Hey, the PO of my truck actually cut 2 - 4x6 speaker holes in the dash! I didn't find that out till I pulled the glued on dash vinyl that extended over the pad
1986 C20 Scottsdale
Instagram: C10sofOC
Old 10-10-2018, 06:20 AM   #14
Andy4639
Old member
Andy4639's Avatar
I remember reading your post on that one!
Old 10-09-2018, 05:48 PM   #15
S_Gibson
S_Gibson's Avatar
Would two 4x6's fit and do better than two 4" round? I have an old Kraco deck in mine and someone has put bookshelf speakers under the seat.
Stupidity was meant to be painful!
S_Gibson is offline   Reply With Quote
Old 10-12-2018, 10:51 AM   #16
rpmerf
rpmerf's Avatar
My setup. Not great, but it works well. I think the piece of wood on the bottom is zip tied to the factory bracket and there is no connection between the speakers and the bracket. It is just holding it in place. Stick on weatherstripping around the edges for a tight fit.
1997 GMC Suburban
