10-08-2018, 02:06 PM | #1 |
Reading A/C gauge
What scale do I read on this gauge for R12 This is the low side with the truck idling. The compressor and clutch are kicked in.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
10-08-2018, 02:17 PM | #2 |
Re: Reading A/C gauge
Black scale, the second one in reads PSI, pounds per square inch pressure on you low side. In the picture it is reading about 73.5. The second scale out from the center that is marked R-12 is telling you what your evaporator temperature is at the indicated psi. Both should be in the low thirties with the right charge and the engine speed up, say around 1500 to 2000 rpm, with the interior cooling down.
1968 SWB Step Side, Big Block, 4L80E , Running! |
10-08-2018, 03:15 PM | #3 |
You read the outside red numbers on the inside red dial.The gauge face reads starting from the outside kg/cm², PSI, R502, R12, R22. So R12 is using the inner most red dial BUT using the outside row of red numbers for the same dial. (R12 & R22 are using the same dial, R22 uses the inside #s, R12 uses the outside #s) In the pic it is reading 72. Yeah, clear as mud, right?
So, reading from the center of the gauge out: R22=43; R12=72; R502=35; PSI=73.5; Kg/cm²=just under 5.2 |
10-08-2018, 03:18 PM | #4 |
Thanks for the help. Here is the high side. I am trying to figure out what is wrong with the A/C. It has the right charge, Charged from a scale. Under the hood the suction hose to the compressor is sweating real good. I can feel the expansion valve cycling refrigerant by holding my hand on the evaporator output line. I do not know why the low side is so high. It has a new pro ten compressor. Heater hoses not hooked up. Today the temp is 82 here and my center vent reads 62
10-08-2018, 04:41 PM | #5 |
Does your truck have factory A/C? If so, the correct charge (based on the '71 service manual) is 3 lbs, 4 oz. With engine at 2000, ambient at 80°, high side should be around 185 -195 psi, low side approx. 30-35 (POA, based on altitude.) discharge temp @ 38° - 41° at right hand outlet. My personal experience, I can almost always get cooler temps with a good system.
One way to confirm you have the correct charge - if your system is stock you should have a sight glass on the receiver/dryer. When the system is at full charge you should see no or very few bubbles in the glass. |
10-08-2018, 06:30 PM | #6 |
Who Changed This?
Did you evacuate the system after installing the new compressor? Standard practice is to also replace the receiver/dryer whenever the system has been opened. If you did not evacuate the system, air and moisture may be the culprit. Pressures like this indicate that the flow is too high. (STV and/or POA out of spec). But the question about evacuation of the system is the main issue, for me.
10-08-2018, 06:52 PM | #7 |
The truck a 72, has factory ac. about 18 months ago I had the system apart and flushed the lines, evaporator and condenser with a/c flush. Installed new compressor and dryer. vacuumed and charged. I had no bubbles in the sight glass. It cooled to 48. Lately it has not been cooling good, no bubbles. I put the gauges on it and was surprised to see over 70 on the low side. I did some research and thought the compressor was going bad. So I put another new one on and dryer. I have tried a new expansion valve with the same results as the original one. Do you guys think that the poa valve would cause such a high low pressure reading?
10-08-2018, 04:20 PM | #8 |
Looks like they are close in reading. So either low on charge or the compressor isn't working. Is the compressor cycling on and off?
https://www.aircondition.com/tech/qu...ith-Gauges-FAQ
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 10-08-2018 at 04:26 PM. |
10-08-2018, 07:29 PM | #9 |
Wanted to help but read some confusing stuff here. You are reading psi always. The red r-12 scale tells you what your suction temp “should” be at that specific pressure. You use a scale to check what that should be specific pressure given and specific temperature.
You said your suction line is sweating. That is good. Do you have adequate airflow inside that cab? Do you have adequate airflow across your condensing coil? The high pressure vapor line going into the condenser should be very hot. You shouldn’t be able to keep your hand on it at all. The line coming out of the condenser should be much cooler but still warm. This will let you know if the condenser is adequately removing heat. Are you sure you aren’t overcharged? Those pressures don’t seem that far apart but usually if a compressor is bad you don’t see much differential between the suction and liquid side. My guess is overcharge. I’d charge it right to the point where your sightglass bubbles disappear. Then your done. This is assuming the expansion valve has had time to equalize. Last edited by Slowguy; 10-08-2018 at 07:42 PM. |
10-08-2018, 07:50 PM | #10 |
Moderator
The poa will stick sometimes. Tap it gently on the side while the AC is running, sometimes that will free it up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-08-2018, 08:06 PM | #11 | |
Who Changed This?
You know, where he walks up to the Coke machine and hits it just right to get a free Coke?
10-08-2018, 08:32 PM | #12 |
I tried that today but it didn't change anything.
10-08-2018, 09:58 PM | #13 |
Thanks Slowguy for clearing that up. In my long-winded post I never said the inner scales are in fahrenheit. I thought that was what what RSGT was asking but now I see that I'm slow & dull witted!
to back up Slowguy & ZEKE68, you want to read the PSI scale. |
10-09-2018, 06:20 AM | #14 |
Old member
Get a good fan and place in front of the truck blowing through the radiator. See if the temps drop. One thing a lot of people miss is closing the gaps off around the radiator shroud. You want to force the air through the radiator not around it. Air going through it is what will keep the AC nice and cold even if everything is working as it should if you are letting the incoming air go around the radiator it want never cool good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-09-2018, 09:01 AM | #15 | |
10-09-2018, 09:25 AM | #16 |
After all your testing, I’d say the POA is stuck.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
10-09-2018, 09:31 AM | #17 |
Clay, I think you are right.
10-09-2018, 03:44 PM | #18 |
Your POA is not working right for sure. The low pressure should be hooked up directly to the POA valve, right? There is not another connection unless someone added one someplace else on the low side so just checking.
10-09-2018, 06:32 PM | #19 |
Yes the low side hose is hooked to the Poa
10-09-2018, 06:33 PM | #20 |
I have another poa valve. Is there a way to check if it is moving free and not stuck before it is installed?
10-09-2018, 09:05 PM | #21 | |
Remove the valve or the discharge line from the valve. Hook the low side pressure gauge to the POA valve. Then pressurize the POA valve, I use air regulated to 60 lbs at the evaporator inlet with the expansion valve removed. I use a rubber tip blow gun. For R12 the pressure should be about 30 lbs at sea level, 27 or so for R134a, add 1 lb for every 1000 ft above sea level. The POA is adjustable through the outlet, look inside you will see a hex nut. Its a strange size though. |
10-09-2018, 09:20 PM | #22 | |
10-11-2018, 01:01 PM | #23 |
Subbed.
10-11-2018, 04:01 PM | #24 |
YOU can test the POA in the truck
TO test it idle at 1500 rpm Use a fan and put it in front of condenser (radiater) unplug the blower motor gauge on low side reading should be between 28-30 psig the POA factory setting should be 32 . there are other things to check also , Air in system make sure your heater core is not bleeding by also spray water on the condenser and see if the lowside pressure drops. |
10-11-2018, 04:46 PM | #25 | |
