Old 10-09-2018, 05:14 PM   #1
WB72
Before and After
WB72's Avatar
Seat Belt Install location
Does anyone have the rough measurements to locate the retractable seat belt by the door?
During repair of the cab, I replaced the metal that houses the threaded insert for it. any close measurements will help. I will install a reinforcement plate when installing it now.
This is what I have to work with now. The red circles are the rear seat mounting area.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 10-09-2018, 06:24 PM   #2
Red71gmc
Re: Seat Belt Install location
I have one hole. 6 1/2" from back of cab x 1 1/2" from door seal area. Door seal is actually forward of the hole. I think this is what your asking and helps.
Red71gmc is offline   Reply With Quote
Old 10-10-2018, 10:51 AM   #3
WB72
Before and After
WB72's Avatar
That is a great start Thanks
66,000 miles.
Alberta, CANADA
Old 10-10-2018, 10:44 PM   #4
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Hope this helps. I’m in Edmonton area so you can PM me if you need actual measurements.
http://67-72chevytrucks.com/vboard/a...1&d=1539225758
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
