Plug Wire Order
Plug Wire Order
I took the distributor and cap out of my 350 a while back, and its time to put them back together. my problem is that i cant remember where to start with the wire for the number 1 cylinder. If i have the engine at tdc, and i line the rotor up with one of the metal things in the cap, can i just go from there and install all the wires in order, or is there a cerain spot on the cap i need to start? right now, i have the #1 cylinder wire on the connection 2 clockwise of where the tac/power wire connects. i know this prolby sounds dumb, but im confused as hell. if anyone can post a pic of a correctly installed distributor, with something indicating which wire goes to cylinder #1, i would really be a happy camper. Thanx alot guys dale __________________
2003 yamaha raptor. Stock, but it still hauls!!!! 2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow. 72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon. "dont let yer mind wander, its to little to go places by itself." "Forget the herse, cause i'll never die"-ACDC Back In Black "If It's To Loud, Yer Just Too Old" "I Love Anything Fast Enough To Do Something Stupid In" "Instant idiot, just add beer!!"" |
![]() Join Date: Jan 2001
Looking at it from the top, and clockwaise, the number one is the first one that comes after the wire adaptor plug. Kind of 4/5 O'Clock posistion.
Orlando
70 C-20 Custom Camper Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251 |
order
As a general rule with the engine on top dead center and the rotor pointing towards the #1 cylinder I start with the terminal that lines up with the rotor button then go clockwise 18436572
Hope this helps I dont think it really matters where you start as long as the order is right! You will just have to rotate the distributor to get the timing right.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
HEI? or points, but either way if #1 is tdc on the compression stroke put #1 where the rotor points. Make sure that #1 is on compressiong and not exhaust though or you will be 180 deg out.
"Red-heads not war-heads, Blondes, not bombs, Brunettes, not fighter jets!" Fligh of the Choncords 72 burb 3/4 ton 2wd 06 2500 suburban 8.1L 4x4 84 chev 4x4 diesel 96 Geo Metro with the 4cylbb, lol! Almost 300k just won't die! 89 Honda Civic, runs on the smell of an oily rag! 2008 Aerolite 26qs Travel Trailer (aka "THE BARN") Last edited by RussTburb; 11-18-2003 at 05:38 PM. |
CCRider
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
