Installing vintage air compressor
I’m installing vintage air on my 70 c10. I’m trying to use the low mount compressor bracket the bolts to the factory fuel pump mounting surface on my SBC. It looks like I might have to cut some of the frame slightly to make the low mount compressor work. Just wondering if anyone has tried this before on our trucks. I’m probably going to have have fab up the bracket slightly to make it work.
Re: Installing vintage air compressor
To me it looks like that is sticking way to far out the front, I would install your balancer and water pump to make sure the pulley lines up before you cut anything.
Old member
X2 it looks to be way forward.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Dec 2013
It looks forward but that may be an optical illusion , That front cross member looks bent and pushed back a lot ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Flip fa ya...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#6 | |
-klb
