11-17-2003, 06:13 PM | #1 |
You DA MAN!!!!
Thank you very much for the installation pic's, very much appreciated.I found out that my light box has been modified a little,so that is where I was confused.Now I can weld some tabs on the front to mount the hinge to.All I had was a little tab on both ends where the light screws on now I can start working on it again.GOOD JOB
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-17-2003, 01:13 PM | #2 |
Nice detail on this. This needs to make it into the FAQ section.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
11-19-2003, 01:31 AM | #3 |
I hate to raise this question but how safe is it to have an operating light right on your fuel filler door? If I'm looking at the pictures right the light looks operational.
It's not just what might happen in a minor fender-bender accident it's what might happen if the filler nozzel should damage the wiring. I'd be inclined to make it just a reflector. It seems like the potential for spark and fumes to come together exist.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
11-17-2003, 05:00 AM | #4 |
Texas Longhorn For Life
Great job and nice truck. Oh, and nice hat!
1970 C-10 named HOSS 400SB/TH350, PS, PB, 3.07 gears \m/ Hook 'Em from Austin, TEXAS |
11-17-2003, 09:37 AM | #5 |
Resident Young Old Dude !
Excellent Documentation!!!
I have posted before, I am filling mine through a garden hose right now, ( not driving it on the street yet still ) I want to do just what you did, thanks for saving me a lot of time and aggravation.. Again, Very nice job. Ron |
11-17-2003, 06:11 PM | #6 | |
11-17-2003, 02:40 PM | #7 |
thanks for the detailed instructions... my question relates to the picture of the filler hose that routes under the frame to get to the tank... trying to understand how the fuel runs uphill to get into the tank...??? I guess the new style filler allows this to be possible...???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
11-17-2003, 02:02 AM | #8 |
Awesome job
Great how-to, thanks for the info. Seems pretty straight forward, some items tedious but as you said I'm sure the key is checking your measurments and marks. Keep us posted on other projects.
Jimmie Modern Vintage Autoworks - '70 Chevy C10 - '74 Chevy C30 3+3 Dually - '04 Chevy Colorado Built, NOT, Bought. If you build it...they will ENVY! Drive Slow, Scrape Hard, or Take Your Truck and GO HOME! |
11-18-2003, 10:54 PM | #9 |
454 club
Thanks for the great details and pictures.
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
11-18-2003, 11:11 PM | #10 |
Pronounced "Pew-al-up"
Thanks for the awesome how to! I will use your demo when I do mine. Your really did a great job !!
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
11-17-2003, 09:17 AM | #11 |
PROJECT 7DEUCE
Thank's for the pic's and the really good nice step by step photos..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-17-2003, 08:19 AM | #12 |
Designated A-hole!
Sweet job! Now I know how I am gonna do mine!
Somebody needs to make sure this and the tank install thread get put into the FAQ section!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-18-2003, 10:02 PM | #13 |
Designated A-hole!
REDNEKID I think if you do a search for tennman you will see the original which was for a fleet side.
11-17-2003, 10:05 PM | #14 |
awesome. i wanna do this. that is if i dont shave them first...
70 longbed 496/th400/Ford 9" |
11-17-2003, 12:21 AM | #15 |
INSTALL: Tennman's Sidemarker Fuel Fill on a Stepside
Finally got around to showing the install! I hope this helps everyone. There are alot of pics, so it might take awhile to load them all.
Here is what I used: 1- 1997 S10 fuel filler door with neck 1- 1 1/2 fuel filler hose (see blazer tank install for part number) 3 ft of 5/8" hose 4- 1/4" machine threaded bolts 1 1/4" long 4- nylon lock nuts for above bolts 2- 1/2" spacers for above bolts 1- permacap gas cap (optional) 1- large can of patience!!! Here are the parts I got from the local wrecking yard:
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
11-17-2003, 12:22 AM | #16 |
more pics of junkyard parts
11-17-2003, 12:24 AM | #17 |
sidemarker light
11-17-2003, 12:26 AM | #18 |
backside of light,
You will need to grind smooth the ridges around the bolt holes on this side. Also grind off the white ridges on the ends near the bolt holes.
11-17-2003, 12:47 AM | #19 |
Here is the top of the fuel filler neck. You will need to weld on an exhaust reducer fitting that goes from 2" ID to 1 1/2"OD on the bottom. I cut the filler length to just below the vent hole fitting.
I could only find a 2" ID to 1 1/2" ID so I had the fuel filler hose stretched with an exhaust pipe stretcher.
11-17-2003, 12:50 AM | #20 |
Here is a pic of the sidemarker hole where the lense goes. My fender had this metal backing on it.
11-17-2003, 12:51 AM | #21 |
another pic without the light.
11-17-2003, 12:52 AM | #22 |
Here is the backside of the fender.
11-17-2003, 12:54 AM | #23 |
You have to cut out the basket.
11-17-2003, 01:05 AM | #24 |
All that is really involved is cutting the fuel door to match the width and height of the sidemarker lense. Measure between the white ridges up and down (approx. 2 1/2"), but measure to just outside the bolt holes ( about 1/8" past on both ends turns out just past 3 1/2" length). My fuel door faceplate (big round part) seperated from my hinge piece, so I had it welded together again.
You can see the weld spot on the side in this pic.
11-17-2003, 01:20 AM | #25 |
Drill the holes for the lense and cut out a notch for the light. I used the original screws and just cut them off on the back side.
Now the bolt flanges on the back part of the hinge base will need to be cut off. Sorry no pics, but you will know which ones they are. They are little tabs with nuts welded on the backside. These were used to bolt the hinge on the S10. Feel free to try and make these work for you, but I couldn't, so I cut them even.
