11-01-2003, 01:14 PM | #1 |
tank question.....
is the tank galv. or plain steel, do you need to use a gas tank sealer on the in side of the tank to prevent rust?
why use the steel tank if the ABS tank will work? did you use rubber strips between all mating surfaces? Tim
TIM '71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!! |
10-31-2003, 05:02 PM | #2 |
Nice job
I was wondering if u had it done yet,I finally got most of the parts and ended up getting some parts for my tailgate allso .I am still trying to figure out the side marker, but am waiting on a tank.Thanks alot for the pic's and info.I would like to see the pic's of the fiiler light.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
10-30-2003, 04:57 PM | #3 |
nice job...
could you tell me how you vented the tank??? im in the process of converting my swb 4x4 over to blazer tank,i got the tennman filler done,and the tank installed to the frame just have to run lines ... good luck and thanks for posting jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
10-29-2003, 05:56 PM | #4 |
Confirmed Truckaholic
Thanks for all the information and time you take to post. I'm about to start this same installation and this is very useful.
11-01-2003, 06:10 PM | #5 |
I'm getting ready to do this next week and I was worried about how low the tank was going to hang down. I'm running a 4" drop in the rear. When I was holding the tank up to the frame I was trying to see if I it would go in the frame instead of under the frame. I thought about removing the cross member in the rear of the frame and sliding the tank in that way. My truck is completely torn apart so I don't have my bed on it. I was wondering how much I could raise the tank before hitting the bed???? Do you have any idea?
10-29-2003, 03:26 AM | #6 |
Nice job! Hey, can you get a pic of what it looks like from the rear? I'm just curious on how much of the tank is visible below the rear bumper.
10-30-2003, 08:53 PM | #7 |
I thought this was a modified Blazer tank to fit these trucks? Or is this company making Blazer tanks only?
It seems that there were several items that need to be addressed. I mean if the builder is just down the street from the Truck Shop, maybe you could do some R&D for them and tell them to increase the filler neck during the build. Also increase the hole size/angle so the mounting bolts fit correctly. How does the filler neck line up with the side marker? Maybe they could adjust the angle there also if needed. I would like to do this swap but do not want to work hours to cram and fit it. It would be great to have the details worked out and built right from the start. Like buying headers and then massaging (hammer) the pipes to clear things. Let us know.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
10-30-2003, 10:24 PM | #8 |
I was just thinking that if they make them, they might consider a filler neck in different configurations. As you say, side-marker, bed fill or original Blazer. Options are nice and all that is involved is the soldering of the different necks. I am lazy and would like to order a custom fit. All done and ready to install.
Keep up the good work.
10-29-2003, 02:41 PM | #9 |
Formerly yellow72custom
Nice job...now what are you going to do with all that free space behind the seat, lol
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
10-29-2003, 09:14 AM | #10 |
So much for the easy parts---can't wait to see the step by step on the fuel filler work. Tennman's porcess is nice but seems to leave out too much detail so perhaps your's will either show the way to side market filler or scare us to in bed filler!
I've got two tanks to install and have been putting it off till I'm comfortable with where and how to do the filler. Also hate the idea of cutting the floor support on a metal floor~~~~ |
10-30-2003, 11:35 PM | #11 |
I really appreciate the effort you went through to post the pics and the description. I want to do exactly the same thing on my '68 and put the filler behind the marker light.
Out of curiosity, what are you doing with the old filler cap? I'd like to keep mine where it is for original appearance.
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
11-01-2003, 03:29 AM | #12 |
Black 72 Chevy
Great job.
72 Chevy, SWB, 350engine, TH400 |
10-29-2003, 12:01 PM | #13 |
MOVE OVER
TTT,,, I agree, this would be great in the FAQ section, when I convert my tank!
No matter where you are..... There you are... Buckaroo Banzi |
10-31-2003, 11:07 AM | #14 |
do you think it would be possible on this type of tank to run a filler tube into the fender on a stepside? I am torn between the clean look of a filler in the bed floor, and the sure knowledge that at some point I will have the back filled with sheets of plywood and need to get some gas
OCB |
11-01-2003, 12:32 PM | #15 |
This couldn't have been posted at a better time for me. I plan on tackling this job next and will be looking forward to the side-fill pictures / instructions.
I am running bags at the rear...do you think this tank drops too far below the frame? I'm not laying frame and have no intention of ever doing so (I'm at about a 4.5" / 6.5" front/rear drop). Thanks again for the education. This message board is great! ~gbkwork
'72 Custom LWB 383 ci, Lunati 213 / 219 cam (60101L), 2.02/1.6 heads, Crane roller rockers, HPC coated ramhorns, FIRST TPI, '90 Corvette ECM, , Built 700R4, 3.73 Eaton Posi 12-bolt, Magnaflow dual exhaust, PW, Keyless DL, ECE Hidden Hitch, New chrome all around, 17" Torq Thrust II's, 255/50 & 275/50 Nittos, ART airbags, Rick's custom tank w/ custom in-bed filler, '02 Silverado seats, Rod Doors headliner / A-pillar covers and door panels. |
10-31-2003, 09:07 PM | #16 |
PROJECT 7DEUCE
Nice job and thank's for the very detailed photo's and direction's.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-29-2003, 02:27 PM | #17 |
What capacity is that tank? i wanna do the swap, but would really enjoy a bit larger tank.
thanx dale
2003 yamaha raptor. Stock, but it still hauls!!!! 2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow. 72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon. "dont let yer mind wander, its to little to go places by itself." "Forget the herse, cause i'll never die"-ACDC Back In Black "If It's To Loud, Yer Just Too Old" "I Love Anything Fast Enough To Do Something Stupid In" "Instant idiot, just add beer!!"" |
11-12-2003, 02:17 AM | #18 |
tank
ttt
10-31-2003, 05:23 PM | #19 |
Good Job on the Step by Step
John Sacramento Area 1969 C10 Fleetside |
10-29-2003, 04:11 AM | #20 |
Designated A-hole!
Good deal! We need to get this moved to FAQ section.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-29-2003, 03:45 AM | #21 |
go cyclones
Thanks for the pics more people should do that to help out the rookies like me.
10-30-2003, 10:20 PM | #22 |
Great job on the pictures, wish I had that when I did mine. Your right on the time with the bed off took about 2 hours of actual putting it in after we figure out what we were doing.
11-04-2003, 09:44 PM | #23 |
RUNN over AGAIN!!!
GOOD JOB.........TTT
67-72 TRUCKS ROCK 70 SWB shaved and a 72 front clip.and a poly tank. Peep mirrors and a BIG BLOCK 468 in the making. XNXNXNXNXNXNXNXNXNXNX ,/. EMAIL ME HERE!, Dont pm me please ,/. |
10-29-2003, 02:50 AM | #24 |
Blazer Tank Install With Pics.
Here is the install I promised. Stay tuned for the pics and install of Tennman's Sidemarker Fuel Fill.
Parts list for tank install: 1 - Tank kit from The Truck Shop(PN 69-107092)-166.00 25' - 16 gauge wire from Kragen-2.99 2 - 4 pack Range 5/16"-7/8" hose clamps from Kragen-4.00 each 1 - 1 1/2" to 1 1/2" Exhaust Adapter from Autozone(PN 17519)-1.49 (optional) 3' - 1 1/2" Fuel filler hose from Kragen(PN 80803)-16.99 (optional) 3' - 5/8 fuel hose from Kragen-3.00 7' - 1/4" fuel filler hose from Kragen-7.00 25' - 3/8" fuel hose from Kragen(cheaper than 16'@1.00 per ft)-13.99 2 - 4" bolts 2 - Nuts for bolts Also needed is a cutter wheel or sawzall and someone who can weld. With that out of the way, here we go..... The Tank from The Truck Shop
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-29-2003, 02:55 AM | #25 |
Feel free to paint it whatever color you like. I chose to use rubberized undercoating to help avoid rust.
I removed the spare tire bar by grinding off the rivets holding it on (sorry no pics from before).
