Old 10-29-2018, 06:37 PM   #1
Dhartley70
Hinge
Has anyone ever had the plate that the door hinges bolt to fall down inside the channel that they are in? Is there a secret to getting it back up where it belongs? And how to keep it from falling down again?
Dhartley70 is offline   Reply With Quote
Old 11-01-2018, 04:16 AM   #2
goofy063
Re: Hinge
its not good, the bottom part of the cage popped off from rust or not spot welded properly you will probably have to cut a hole in your kick panel to re weld the cage
goofy063 is offline   Reply With Quote
Old 11-01-2018, 02:21 PM   #3
61K10
61K10's Avatar
Re: Hinge
Mine did the same thing. If i remember right I used a wire with a hook bent on the end fished threw one of the holes, pulled it up and got a bolt in one of the holes (took many tries) when putting the latch back on leave one bolt in the plate(that holds the plate in place) bolt through rear hole of latch, tighten just enough so you can swivel the latch after removing the forward bolt. move the latch and install the other 2 bolts. I think thats what i did as its been awhile. Maybe remove the data plate and cut a hole there? good luck.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-01-2018, 06:15 PM   #4
nsb29
nsb29's Avatar
Talking Re: Hinge
Your other choice would be to turn it over and shake it lol
nsb29 is offline   Reply With Quote
Old 11-01-2018, 06:54 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Hinge
I seem to remember a plug at the bottom of the a-pillar post when I had my body on it's back-side prepping it. Am I imagining it?
Old 11-01-2018, 09:02 PM   #6
nsb29
nsb29's Avatar
Re: Hinge
There’s one on the rocker panel
Old 11-01-2018, 09:05 PM   #7
nsb29
nsb29's Avatar
Re: Hinge
There’s one on the rocker panel But not on the A pillar if you can’t Fish it out surgery is next
