Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-08-2018, 03:50 PM   #1
mick53
Party pulley
I'm having Gaerte Racing Engines building me a I6 292 with 4-71 blower and 3 Rochester 2 barrel carbs. I think the plan is about 5 pounds boost and pump gas for street manors. If I go play at the local drag strip and put a party pulley on the blower can I switch over to a separate fuel system with racing fuel so I don't detonate this very expensive engine? This engine cost more than my first house. This goes in my 53 1/2 ton pickup. Any thoughts would be appreciated. Thank you.
mick53 is offline   Reply With Quote
Old 11-08-2018, 04:45 PM   #2
62bagger
62bagger's Avatar
Re: Party pulley
No suggestion but be sure to post pictures when you get it. I would like to see it. its going to look really cool in when you pop the hood.
62bagger is offline   Reply With Quote
Old 11-08-2018, 04:53 PM   #3
mick53
Re: Party pulley
They just got the block and head back from the painter. Global firethorn red pearl to match the body. Fenders will be black pearl.
Old 12-03-2018, 11:37 PM   #4
'65 chevy lover
Re: Party pulley
What trans are you using?
'65 chevy lover is offline   Reply With Quote
Old 12-05-2018, 01:49 AM   #5
mick53
Re: Party pulley
Upgraded TKO 600 with mid-shift kit. Frankland QC-80 rear end with gleason locker and bicknel torque arm.
Old 12-05-2018, 12:37 AM   #6
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: Party pulley
Any thoughts about just running E85? Then you don’t have to worry about it. I think you can go up to 14:1.
So pending on your static compression and boost PSI you would be fine up to 10-12lbs of boost.
There is a chart on line that will tell you all that.
Good luck.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 12-05-2018, 01:59 AM   #7
mick53
Re: Party pulley
Good luck.
I looked into E-85, my builder, Gaerte Racing Engines tells me the problem seems to be that the octane is all over the place at the pump. It varies wildly between region and batches. One low octane fill up and boom.
Old 02-04-2019, 12:34 PM   #8
Hollow65
Hollow65's Avatar
Re: Party pulley
Look in to a boost timing master, they’re old school tech, retards timing based on boost level. I’ll try and find a pic. For instance at cruise I am at 36* but at boost (10#) it pulls 1* of timing per #. I run 91 octane. Most days.
https://www.jegs.com/p/MSD-Ignition/...47848/10002/-1
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 02-04-2019, 02:29 PM   #9
mick53
Re: Party pulley
Thanks, I will leave that up to my builder. They are using crank fired timing and no distributor. I presume the computer handles that but I will ask.
