LS Motor advice
LS guru's, I found an 04 5.3 LS for my swap complete with motor/tranny/ECM/harness for $1700 with 105k miles and it is drive by wire. Also it is close enough to me to drive out and pick it up. My only question is should I try to find one that is DBC for simplicity and good throttle response or is DBW just as good? I'm a burnout kind of guy so does the DBW hesitate if it senses wheels slipping or is that just with traction control? Thanks.
Re: LS Motor advice
DBW is just as simple as DBC in reality. You wont have traction control so it wont stop the throttle at all.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Re: LS Motor advice
I've done 2 LS swaps. One DBW and one DBC.
The DBW actually has better response than my DBC setup. Your not going to have any issues with the DBW and wheel spin. Plus, the full package of you found for $1700 is a good price. Just make sure you get the pedal and TAC module with the motor. It will save some headaches
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
Re: LS Motor advice
Yep, just got off the phone with him he’s going to throw in the pedal and tac module, can’t wait. Thanks for the advice guys.
Re: LS Motor advice
Re: LS Motor advice
Just make sure you've got the whole system, pedal to throttle blade including harness (and to NOT modify the pedal harness or fab a replacement). The throttle will be plenty responsive, and will not do traction control because you won't have the wheel speed sensors or any of that.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
