![]() Join Date: Feb 2016
1972 Blazer Coil Spring Suspension
I came to the conclusion that I was not totally happy with the ride and braking of the stock suspension and decided to perform some upgrades.
Re: 1972 Blazer Coil Spring Suspension
Took some measurements and pics of the front end before I started.
A guy with a truck
What’s the plan? Always liked this one
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
I am missing a security token, sent a message to the administrator to see how to fix it. Will not allow me to post photos at this time.
A guy with a truck
Usually that happens when your pics are too big or too many. Try reducing size or post no more than two at a time
Getting everything ready for the front coil over suspension.
A guy with a truck
Nice. Which kit are you using?
I chose QA1 because I did not feel like removing the cross member.
Checking the ride height, wheel offset and look.
Changing to four wheel disk brake master cylinder, proportioning valve and hydro boost.
Measuring and preparing rear of truck for coil spring rear end.
A guy with a truck
Very cool. Are you having to modify the upper coilover mounts to work with your 4wd frame?
I am in the process of having a custom set of C-Notch plates made with upper coil over mounts. I will update the thread when they arrive and I begin to install them.
