![]() Join Date: Mar 2015
Power steering pump Bracket
I am putting a 72 blazer back together and can't find info on how the rear section of the power steering Bracket bolts up to the motor. It is a two piece bracket and I think two bolts go in the front of motor and the other goes to the motor mount. I think the Bracket is bent but not sure how I took it off and don't remember this much trouble but it's been a year I am trying to post a pic but I am just beginning to use this forum and have not figured out how yet
Thanks |
#2 | |
Re: Power steering pump Bracket
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Yes. That's it. It must have gotten bent somehow. Doesn't it attach at the motor mount and is there a secret to getting to that boost after the Bracket is installed.
Thanks |
In his pic, the ear at the top bolt to the motot mount with one of the bolts that hold the motor mount to the engine
Here is another one that shows it mounted on the block. The bolt in my first photo is just holding the two pieces together in the position they would be in. As indicated above, there are two bolts that bolt to the block front and the motor mount bracket part uses the motor mount bolt to fasten it to the side of the block.
Thanks for the help.
