12-08-2018, 09:39 AM | #1 |
Simple stovebolt engine storage/test stand
Jeg's has the stands for $49 and with a 25% off a little cheaper at Harbor Freight. Allows using starter with bell housing, and flywheel. Clutch and trans can be added. Rear perches would be horizontal for earlier bell housing. I will add engine pic in a few days.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 12-08-2018 at 09:41 AM. Reason: words |
12-08-2018, 05:49 PM | #2 |
Re: Simple stovebolt engine storage/test stand
Completion.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
12-08-2018, 09:17 PM | #3 |
Great idea. I tried hanging a 6 from the original version. Does not work so well. Also with a few more mods you could make a really inexpensive test stand. HMMM
12-08-2018, 09:58 PM | #4 |
Agree Paul, stand can easliy handle a gas can, radiator and battery with added brackets. Or just a radiator.
Centers on all engine mounting points -- front to back is 34" give or take an 1/8". Make mount holes larger for adjustment. I used 1.5 inch x 1/8 in thick angle and a piece of 2 ". Extended the bottom bar with 2" square tubing. Used bolts that came with stand. Everything yellow added.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 12-08-2018 at 10:12 PM. Reason: words |
