Old 12-08-2018, 11:58 PM   #1
Streetglide2015
Question 64 C10 with heater blower glitches. Advice?
I just bought a beautiful 64 C10 short-bed, which has been basically restored. It has Thrift Air heat, but the fuses keep blowing. Each time I replace the blown fuse, I switch on the fan (all speeds), it runs for about 20 seconds, and fuse blows again.
Since the switch, and the fan motor seem to operate, could this be a resistor problem? Is there a fan motor relay also?
I located the resistor, but cannot seem to determine the location of a relay.
Any ideas on what else may be the cause?
Thanks!
Streetglide2015 is offline   Reply With Quote
Old 12-09-2018, 12:42 PM   #2
Streetglide2015
With all the experience here, can anyone help me with this?
Thanks!
Old 12-09-2018, 12:53 PM   #3
kazoocruiser
Re: With all the experience here, can anyone help me with this?
Maybe the brushes in the fan itself have worn out. If it is binding because of it, that would cause excessive current draw.
kazoocruiser is offline   Reply With Quote
Old 12-09-2018, 02:08 PM   #4
cryowagon
There is no relay. Power goes from the fuse to the switch, from the switch to the resistor, then from the resistor to the blower motor. On the highest speed, I believe the resistor is bypassed, so if the fuse is blowing on high, its probably not the resistor. I think that if there is a short in the switch, it would blow the fuse immediately.
cryowagon is offline   Reply With Quote
Old 12-09-2018, 08:16 PM   #5
Streetglide2015
That sound very possible. Each time I switched on the fan (after replacing a fuse) I twisted it right to high. As I said, it runs for about 10-20 seconds, then blows fuse. It seems like a pretty simple problem to diagnose, and a new resistor is cheap enough to give it a try.
Thanks!
Old 12-09-2018, 11:33 PM   #6
kazoocruiser
Thanks!
If you have access to a multimeter, you can test the resistor pack to make sure it is bad before you buy a new one.
You can use a multimeter to test the amperage draw across a load. If your entire circuit is rated at 15 amps, and then the fuse blows, you have an over-amp condition.
I think someone already indicated there are no resisters in series when the fan blower is on high.
You could unplug the fan, and if a fuse blows then, it's the wiring.
If it doesn't blow then, I think it would eliminate everything but the fan.
You might actually remove the fan and do an inspection to see if the blower wheel is able to rotate freely. Maybe it needs to be checked for free rotation and lubrication.
Old 12-10-2018, 03:03 PM   #7
shp4man
shp4man's Avatar
My truck's fan motor was seized when I got it. Took it out, drilled a tiny hole in the lower bearing, lubed it up with a grease injector, 2 years and still working.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 12-10-2018, 06:33 PM   #8
Streetglide2015
Thanks much for all the assistance!
Old 12-12-2018, 12:30 PM   #9
WhippinSaw
WhippinSaw's Avatar
My 63 had the blower wire short where it goes through the firewall.
Didn't blow a fuse but started a fire and filled the cab with smoke.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 12-12-2018, 02:53 PM   #10
mikie 1954
Make sure you have the right size fuse in it to. When I bought mine someone had put the wrong fuse in it and it kept blowing until someone on here told me to check it. Good luck
mikie 1954 is offline   Reply With Quote
Old 12-11-2018, 07:27 AM   #11
PGSigns
PGSigns's Avatar
Re: 64 C10 with heater blower glitches. Advice?
Unplug the fan and see if it still blows the fuse. If it does its in the wiring to the fan and you can look for shorts to ground in that wiring. If the fuse does not blow pull the fan and bench test it. Also what amperage fuse are you putting in it?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-11-2018, 08:57 AM   #12
The Rocknrod
Moderator
The Rocknrod's Avatar
Maybe the answer is here?: http://67-72chevytrucks.com/vboard/s...d.php?t=776911
Old 12-13-2018, 11:47 AM   #13
chevy_mike
Never Ending Projects
chevy_mike's Avatar
You had two different posts about the exact same thing. I have merged these two threads into one.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
