Old 12-16-2018, 06:52 AM   #1
Wgesnerjr
Wgesnerjr's Avatar
Gauge cluster shift cable fix
How many of us have had the shift indicator stop working only to find this? I found it yesterday. Since the indicator wont work without this guide, I decided to come up with a better, more permanent solution.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 12-16-2018, 06:59 AM   #2
Wgesnerjr
Wgesnerjr's Avatar
Re: Gauge cluster shift cable fix
This first step was finding the broken piece. Since it didn't fall out onto my feet, it had to be stuck in the dash. I found it lodged between the steering column and the heavy mounting bracket.
I briefly thought about fiberglassing it back in but knew it might just break again. Not sure if the gauge cluster housing is available new as I am running an electric speedo from a 91 suburban in my LS swapped truck.
So off to Ace Hardware to find a solution.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 12-16-2018, 07:07 AM   #3
Wgesnerjr
Wgesnerjr's Avatar
I decided that anything I did should used the metal dash for support rather than the brittle 28 year old plastic housing.
After a long time in the hardware section, I came up with this.
I would mount the screw to the metal dash using the two jamb nuts on either side. Then adjust it out to mimic the broken plastic guide. The brass thumbscrew would "float" on the threads and act like a pulley to guide the shift cable down to the shifter bowl.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 12-16-2018, 07:09 AM   #4
Wgesnerjr
Wgesnerjr's Avatar
You might not have noticed but the original guide does not have a center hole in it. So carefully, I drilled it out.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 12-16-2018, 07:13 AM   #5
Wgesnerjr
Wgesnerjr's Avatar
Next step was to mate it up to the gauge housing. Using it to guide me, I marked the dash where the hole was. This would be where my new contraption would be mounted.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 12-16-2018, 07:17 AM   #6
Wgesnerjr
Wgesnerjr's Avatar
Drilling the hole was a little hard since the drill and the shifter wanted to occupy the same space. Once hole was drilled I slipped the rear nut behind the metal and used my finger to hold it. Then treaded the screw in from the front.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 12-16-2018, 08:51 AM   #7
Nice fix. I just have a white mark on the top of the column for now till I fix mine.
Old 12-16-2018, 12:58 PM   #8
4x4k30
4x4k30's Avatar
nice fix you did a real nice job there you should get a patent on it
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 12-16-2018, 03:30 PM   #9
Wgesnerjr
Wgesnerjr's Avatar
Thank you. Just trying do better than old factory stuff. I'm already thinking of a better way to fix.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
