12-17-2018, 11:30 PM | #1 |
Trailing arm e brake bracket line removal?
I have the whole rear end off the truck and want to replace the trailing arm bushings. Also taking the rear end out to clean and paint. How does the e brake line come out of the bracket on the trailing arm. The cotter pin comes out but the gap is smaller then the brake line fitting? It's a lwb step with rear drum brakes. Thanks for any help
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
12-18-2018, 07:40 AM | #2 |
Re: Trailing arm e brake bracket line removal?
Are you talking about the E-brake cables? They get tapped back and the cable will fit through the slot in the bracket. I have seen a couple that over the years the bracket has been closed up a little and I had to take a screw driver and pry them open just a bit.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-18-2018, 09:23 AM | #3 | |
