12-22-2018, 11:42 PM | #1 |
At the body shop.
Bench seat score!
Scored a nice bench out of a 98 crew cab. Got the back bench, less wear and tear I think.
Also looks like the slider stuff is all there just missing the handle. Now to figure out which truck to put it in.
" That didnt make it any newer " " Dont antique the equipment " |
12-22-2018, 11:48 PM | #2 |
Re: Bench seat score!
A score is always nice. Seats look great
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
12-23-2018, 12:42 AM | #3 |
Will it fit in my 1981 C-10?
12-23-2018, 04:41 PM | #4 |
I have that seat in my 71 gmc i like it but you cant fold the arm rest down or up unless you unbolt the seat.it hits the gas tank and you cant move the seat forword. Becuse to install it its slide all the way foward to mount behide the hump in the floor
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
12-23-2018, 04:42 PM | #5 |
Here's another picture
12-23-2018, 04:49 PM | #6 |
Not my seat but you can see what im talking about. This guy made a spacer to mount the seat i just made the seat fit behide the hump by sliding it foward. So thaers no movment to my seat. So the arm rest is eher up or down. The picture above are when i just installed it. I ended up putting the arm rest up. Its in they way down. If you dont have a gas tank in the cab then it would work fine
12-23-2018, 05:06 PM | #7 |
At the body shop.
Well that's depressing to see. But thank you.
Merry Christmas!
12-23-2018, 07:04 PM | #8 |
Those are like mine except I got the fronts because I wanted the forword / back adjustments. I moved my tank to the rear, you might find a set of sliders to swap in instead of the stationary ones.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
12-23-2018, 07:45 PM | #9 |
At the body shop.
The slider stuff is all there.
Needs a handle and a cross cable? Or what ever it's called.
12-23-2018, 09:38 PM | #10 |
They have sliders its just the way i mounted them. If you mount them like in the picture with the blue seat you can slide them foward and back. My Seat is slide all the way foward on the rails so i could mount the seat behide the hump on the floor. If you use the stock frount hole on the floor and the frount hole on the new seat rail .Make a spacer like in the picture and you can slide them foward or backward as you please. Sorry for the confusion. and yours are 60/40 split. Not a full bench. But they do look similar
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) Last edited by 71gmcC15; 12-23-2018 at 09:43 PM. |
