12-23-2018, 11:21 AM | #1 |
column to rag joint
I need some help getting from my column 1"DDX3/4 to the rag joint extension 1"x3/4. What do I need at the column to the 3/4 DD for vibration or movement, there was a greased socket with a rubber boot, which I assumed was for any movement
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
12-23-2018, 03:09 PM | #2 |
Re: column to rag joint
Here’s what I’m talking about. The end of the column is 1’ OD with a 3/4 ID. Can I put a coupler there or should I put some kind of joint for movement? Thanks
12-24-2018, 10:29 AM | #3 |
It's hard to see in your pic what type/size you got coming off the rag joint.
The rag joint will take care of the vibration issue. If it is DD and the rag joint deflection is not excessive I would weld a like extension on it and continue with more DD shaft to the column 1"DD and install a 1"DD X 1"DD or 1"DD X 3/4"DD (depending on your application) universal at that point. If you require a bottom u joint at the rag joint (excessive deflection) DD shaft, you'll have to a Heim Joint somewhere in the middle to keep the whole shebang from flopping around. |
12-24-2018, 11:14 AM | #4 |
They both accept 3/4 DD. I figure the rag joint would take care of vibration, but there was a greased joint where the old DD and column came together. And it was splined.
12-24-2018, 11:26 AM | #5 | |
Like this? ^^^^^^^^^^^^^^^^^^^^ You no longer are using that I'm assuming since it hooks up to a factory 3/4-36 spline on the end of the factory column. You measure DD shaft across the wide radiused ends, most after market columns are 1"DD. |
12-24-2018, 11:35 AM | #6 |
That's it! The new column accepts a 3/4 DD. I was going to put a new shaft from the rag joint extension to the new column and insert a set screw at the column, but wasn't sure if I needed a u joint there seems the original had what you pictured. Thanks for the help
12-24-2018, 12:53 PM | #7 | |
That's not the way to do it. You will need a 3/4 x 1 universal for misalignment …..trust me. |
12-25-2018, 10:10 PM | #8 |
Here is a pic of mine with a stainless steel u joint
Fuzzy |
