Old 12-31-2018, 10:01 AM   #1
solidaxel
solidaxel's Avatar
Water pump heater connections?
Just changed out the 180* hose on the heater nipples and after adding the hoses for the heater the 3/4 pipe is leaking at the connection with the aluminum pump.
What is the correction for this, besides changing out the water pump?
Is this just pressed in, if I remove the nipple what is the replacement besides a AN hose and threading the pump?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-31-2018, 11:55 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Water pump heater connections?
Think I'd just cchange the pump...those are pressed in I believe....you could possibly tap it to npt...I think I saw someone do that before....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-08-2019, 02:53 PM   #3
indymachinist
They are just a press fit. You can tap to npt if you so desire. I did on mine and am using AN fittings.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 01-08-2019, 03:44 PM   #4
solidaxel
solidaxel's Avatar
Thanks, that is what I wanted to hear!
LS 3 4L70E
Old 01-08-2019, 09:37 PM   #5
steven03
I had to pull out the stock fittings and weld 45 degree aluminum fittings to mine so it would clear the hotside on my setup.
steven03 is offline   Reply With Quote
Old 01-09-2019, 07:33 PM   #6
e015475
e015475's Avatar
I have tried pulling them out and twisting them out with no luck.
I got them out by cutting them nearly flush and collapsing the tube with a cold chisel. Once you get a piece of the tube to lay over, you can drive the tube out the back side of the hole.
The holes the tubes come out of are oversize to a NPT pilot by about .030-.050". I went ahead an tapped them anyway with a 1/2" and 3/8' NPT tap and ran it all the way to the end of the tap.
Because the hole is oversize to the pilot diameter the threads won't be fully formed for the full length, I suspect they may leak. I'll probably put the fittings in with JB weld to backstop against that happening
e015475 is offline   Reply With Quote
