01-03-2019, 01:36 PM | #1 |
headers
I have a '69 C-10 with a stock 350 in it. It has headers on it now and I'm gonna replace them. Any suggestions?
01-03-2019, 01:41 PM | #2 |
Re: headers
Stock Manifolds, headers are a real pain.
01-03-2019, 03:05 PM | #3 |
Re: headers
Yea,,,I'd thought about that since the engine is stock
01-03-2019, 04:40 PM | #4 |
Re: headers
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
01-03-2019, 07:58 PM | #5 |
Re: headers
yep stock motor means stock manifolds no maintenance after install..
01-03-2019, 08:08 PM | #6 |
Re: headers
im about to go back to ram horns. I just want clean and simple.
01-03-2019, 08:54 PM | #7 |
Re: headers
Heedmen headers. Just put new ones on my 69 c10 with a 350. Number 5 plug takes a few minutes to get out. No clearance issues.
01-03-2019, 10:30 PM | #8 |
Re: headers
If you buy cheap $99 headers, then every bad thing you've heard about headers WILL happen to you. If you buy good headers, which are pricey, you'll have no more problems than you would with stock manifolds. A thick header flange is key. For a stock engine, stock manifolds are perfectly fine. If you decide on headers, get a set of tri-y's. They build power down low, where it will be useful on a daily driver or towing rig. The 4 into 1 headers make their power in the higher rpm range, not where you do most of your driving. Splurge for ceramic coated if your wallet can accommodate that. But again, stock manifolds are just fine on a stock engine. Even upgrading to the 2-1/2" Corvette manifolds won't do much for a stock engine, other than make it a pain in the @$$ to route your exhaust and mount your accessories.
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 01-10-2019 at 07:10 PM. |
01-03-2019, 10:53 PM | #9 |
Re: headers
2 1/2" 'vette rams horns.
01-03-2019, 11:46 PM | #10 |
Re: headers
2 1/2" rams ,
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-04-2019, 08:53 AM | #11 |
Re: headers
I seen this pic a while back and this is what I did. Thanks Grumpy.
01-04-2019, 10:13 AM | #12 | |
Re: headers
The hardest launches it will do are in front of my neighbors house Who just built a total pro Cuda show car with a super charger with 3 chrome Holleys on a 499 sticking 3.5' out of the hood it gets about 1.5 miles to the gallon , I haven't seen him turn it loose yet ? It sounds great pretty sure it's a pegleg , It's been running the show circut pretty much lately My neighbor (his father) on the other side has a nice '47 on a S10 frame he just finished another peg leg . So this little small block with a rock chrusher and 3.73 posi should get the neighbors going in a fun way , It's a good thing to have neighbors who are interested in the same thing as you are . No one around here complains about large compressors running all day or the occasional loud engines running late at night https://www.youtube.com/watch?v=rgFW7cBqwCM
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 01-04-2019 at 10:37 AM. |
01-04-2019, 08:53 AM | #13 |
Re: headers
Running a set of set of Summit brand headers. They have surface rust on them now. I will be cleaning them up. On a stock motor probably best to go stock exhaust. I have a pretty aggressive cam in my 350 so I went with a set of long tube headers.
01-04-2019, 09:12 AM | #14 |
Re: headers
These fit good. Heedmen headers
01-04-2019, 11:30 AM | #15 | ||
"I ain't nobody, dork."
Re: headers
Headers get a bad rap because most people overtighten the fasteners and warp the flanges, or use crappy gaskets that blow out. I've installed headers on dang near every V8 vehicle I've ever owned, and have not had the problems everyone associates with headers.
I will add this though... changing spark plugs on a SBC with headers could be a new Olympic Sport. Get's a little tight, but if you take your time and know a few tricks, it gets easier over time. Gary
01-04-2019, 01:21 PM | #16 |
Re: headers
I had headman long tubes on my old truck, never had a problem. It’s been said many times, don’t go cheap when it comes to headers
01-04-2019, 03:38 PM | #17 |
At the body shop.
Re: headers
Doug's headers on 2 of junkets.
No plug clearance issues. No gasket issues. Zero maintenance basically
" That didnt make it any newer " " Dont antique the equipment " |
01-05-2019, 11:13 PM | #18 |
Re: headers
I'm running summit brand ceramic headers with no problems. Look good. No leaks.
I did use fel pro gaskets though. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
01-06-2019, 09:28 AM | #19 |
Re: headers
I was wondering when we would have our next discussion on Headers vs manifolds. Headers are an effective as well as harmless mod. Effective meaning if your engine is build up bad to the bone they are the final equation for getting that horsepower producing air through the pump. Harmless meaning, while a stock motor may not see much beneficial gain, they don't hurt a thing.
As far as looks go, I like the look of headers. They both look clean (except for the factory heat deflectors), but personally I see tubular headers as being the clean option. Also the performance option, for looks. And you are ready for anything else you decide to throw at your mill. As far as reliability goes it's a draw in my eyes. Personally, I have had more issues with manifolds than headers. Run enough of these trucks stock long enough and you would know. And the problems that 'can' occur with headers I would rather deal with than the problems I've had with manifolds. It really comes down to what you like. You can't go wrong either way as long as you don't buy cheap crap... not that I didn't get 15 reliable years from a set of cheap headers I had to have installed in Flagstaff on my '71 Custom Camper when one manifold blew out descending the North Rim of the canyon. You would think cast iron would last a lifetime, and some seem to be. But I have to wonder about anything new made in China with what seems to be their inferior metallurgy.
01-07-2019, 12:03 AM | #20 |
motor exploder
Re: headers
Funny you say that Special-K, the one vehicle of mine that did have manifolds (they were on it when I got it) was my '65 Bel Air wagon. Drivers side manifold cracked, then I put headers on it!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
03-01-2020, 07:02 PM | #21 |
Re: headers
03-01-2020, 09:29 PM | #22 |
Re: headers
I never had issues with my cheapy Hedmans. Drove it daily for 16 years. Put gaskets on once. Never did anything with the collectors....I had donut gaskets in place.
03-01-2020, 10:08 PM | #23 |
Re: headers
I just installed Summit Ceramic coated headers and the have real thick flanges and fit perfectly on my 69 C20 350. Also did single barrel to 4 barrel Holley 600 and dual plane intake. Totally woke it up. Its not a dog anymore. Lots of power. Power steering is next.
03-01-2020, 11:03 PM | #24 |
Re: headers
I have Heddmans. The PO had mismatched rams horn stock exhausts. One was pre-smog, and the other had holes for A.I.R. inputs. Different displacements. New hedders were more practical than stock exhausts.
07-12-2020, 01:26 PM | #25 |
Re: headers
I've read 4 or 5 threads on headers and not one mentions problems on the starter side of the engine. That has always been the biggest problem with headers in my history, esp my 1971 C10. The headers are actually touching the starter! I recently purchased it and have not driven it enough that the starter won't turn.......but I am sure it would happen except that I am going to put manifolds on it before it happens.
