![]() Join Date: Mar 2006
Help with 62 Upper steering bearing
I have a 62 C10 that I believe has an original steering column. It has all of the 62 turn signal pieces and a "custom" steering wheel. I am trying to replace the upper column bearing / horn contact and so far have purchased three - 1 "NOS" (which had a diameter too big for the column) and 2 from parts houses that were confident they were sending me the right part. Both of the bearings I received had a smaller horn contact surface with ribber on either side of the ring but more importantly, both were too "shallow". When installed, the new bearings did not allow the turn signal cancel cam to sit far enough down into the bearing to allow the nut to go on the steering wheel. One thought was to see if I could press the inner bearing race down into the bearing further, but I'm afraid that will ruin the new bearing. Any help is appreciated. I'll try to attach a couple of pics that show the bearing sitting on the cancel cam. The new bearing shows a much bigger gap to the cancel cam.
Thanks for any help Bob Last edited by bhap; 01-05-2019 at 02:06 PM. |
One foot in front of the other
![]() Join Date: Aug 2008
Re: Help with 62 Upper steering bearing
Whats the top of the column look like?
Added photos above... the bearing "ring" sits flush to the top of the column. The center race determines how high the steering wheels sits. If the new bearing is not sitting too high, can I compress the lower spring to push the shaft up in the column to attach the nut? Nothing that I have read says you need to compress the lower spring or shaft.. any help is appreciated.
Ive' never seen one that has that rubber that you are showing in your pic.
Top pic is new bearing... old bearing housing was plastic...
