01-06-2019, 03:27 PM | #1 |
Inline Fuel Pump Location on 1st Gen Blazer
I have a question for you experienced LS swappers. I have a 72 Blazer that has an LQ9 installed. I'm finally getting to the fuel system install. I have a brand new original style tank with the neck swapped over, an inline walbro pump, corvette regulator, and nylon lines and quick connect fittings. I'm about to mount the pump and run the lines and I'm confused about where to put it.
I can put it close to the tank, but this puts it near the top of the tank. Or I can mount it about 3 feet father forward where the frame drops down and get it down a little lower. I was convinced the inline pump would be fine, but most people using them successfully have in-cab truck tanks, so the pump is mounted below the tank. Unfortunately, the money is spent and I'm not interested in buying an intank pump at this point. So what do you think: Close as possible to the tank and high, or 3 feet farther forward and closer to the midline of the tank? Will either work?
My LS Swap: http://67-72chevytrucks.com/vboard/s...d.php?t=718573 |
01-06-2019, 03:36 PM | #2 |
Re: Inline Fuel Pump Location on 1st Gen Blazer
I have mine mouted above the tank....as close to the tank as possible will make life easier on the pump
01-06-2019, 03:49 PM | #3 |
Thanks Mongo. That was my gut feeling as well. I'm already sucking fuel up the sending unit. Minimizing the distance is probably more important than height. Hope you've gotten some good miles out of that pump!
01-06-2019, 03:59 PM | #4 |
Over 20k and still going
01-08-2019, 10:32 AM | #5 |
I agree with shortest distance possible but at the same time I would go low even if it required going further from the tank. Think of it this way, up high it has to suck to prime, now when you siphon gas think about how when the hose end is below the fuel level it will come out on its own. The thought process is if it’s below the fuel level it won’t have to suck to prime as fuel will naturally drain to the lower level. Ofcourse this thought all depends on if you can get the pump to the lowest fuel level you will ever have
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
01-08-2019, 10:39 AM | #6 | |
01-08-2019, 10:59 PM | #7 | |
01-08-2019, 11:47 PM | #8 |
Mount it close to the tank and it'll be fine...
