01-09-2019, 10:18 AM | #1 |
Aluminum Gen I Vortec timing cover..If you're tired of plastic
01-09-2019, 10:49 AM | #2 |
Re: Aluminum Gen I Vortec timing cover..If you're tired of plastic
I looks like it is cast for a crankshaft position sensor, but it looks like it wasn't machined.
It doesn't look like it will work on stock engines. EDIT: It says in the description: Timing Cover, 1-Piece, Aluminum, Black, Chevrolet, Small Block, Without Crank Sensor, Each The only bad thing about the plastic ones is they aren't re-usable. The gasket is glued/bonded to the cover. But they are cheap enough that it doesn't matter. They don't have issues with leaking, and I've never seen one crack/break. |
01-09-2019, 10:55 AM | #3 |
I did some more digging.
They do offer 2 covers that will work with crankshaft position sensors: https://www.summitracing.com/parts/hly-21-153/overview/ https://www.summitracing.com/parts/hly-21-152/overview/ |
Tags |
gen i, timing cover, vortec |
