Old 01-12-2019, 12:29 PM   #1
landarts
landarts
kick panel vent pins and springs
I am trying to knock a few more items off of the punch list with the 72 Fixrupr build. I tore down the fresh air vents a few years ago and sand blasted, painted and replaced worn out foam inserts. I misplaced the pins and springs that help hold them in the kick panels. Is there any place out there that sells them? I have looked and just not able to find them. First image is what I am looking for. Second are mine ready to go back together.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 01-12-2019, 05:22 PM   #2
landarts
landarts
Re: kick panel vent pins and springs
Never mind I found a way to make it work with long screw, cut the head off and threading it up and down raise and lowers so you can remove or install. After the final assembly I will post a picture so if anyone else gets into need for the same.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-12-2019, 11:21 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: kick panel vent pins and springs
Junkyards would be my suggestion but it sounds like you figured it out.
You may could use a couple of old ink pen springs and some small rods to.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
