Old 11-23-2003, 03:59 AM   #1
skokie
skokie's Avatar
Year of engine?
Is there a number on my engine that I could look up and see when it was made?
If so where would it be located?
skokie is offline   Reply With Quote
Old 11-23-2003, 04:04 AM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Yes. There is a machined pad on the front of your engine, right where the passenger side cylinder head bolts to your block. It should have a sequence of numbers, and a 2 or 3 letter code (ex. TDJ).
There is another, less accessible place too. On the back of the block, behind the driver's side cylinder head, there is a large number cast in (ex. 3970010). The letter code is proably the most useful, along with the number code, you should be able to pinpoint what and when your engine was made.
Decode the numbers at www.nastyz28.com , or www.mortec.com . Nastyz28 has suffix codes (lettered code), while Mortec does not
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-23-2003, 06:19 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Also on the side of the block, there is a code that indicates the shift, conveyor line and month, day and year the block was cast. Exmp: CON2 (clock symbol w/big hand on a number=7pm) F 26 8 [June 26, 1968] A=Jan,B=Feb etc. The year numeral is only 1 digit so you have to guess the right decade.
Old 11-23-2003, 02:33 PM   #4
skokie
skokie's Avatar
Ok heres what I found. This was on the ledge near the alt. 1m0(or o)82767SVP.
Old 11-23-2003, 07:08 PM   #5
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
The casting numbers are not always on a machined surface......My block number were casted in to the block.....
67Fleetsidedream is offline   Reply With Quote
Old 11-23-2003, 08:58 PM   #6
Blazer1970
Blazer1970's Avatar
Casting numbers (and casting date codes) are never on a machined surface. They are cast into the block (or manifold, or head, or whatever) at the foundry. Block ID numbers are always stamped on a machined surface - they are stamped at the engine assembly plant.
Oh, and Skokie, those numbers look odd. Is it a small block, big block, 6 cylinder, or what?
Blazer1970 is offline   Reply With Quote
