Old 01-19-2019, 04:12 PM   #1
Moeller
216 to 235 swap - carb. fitment problems?
Hi All,
I just put in my newly rebuild 235 in my 1953 truck, and wanted to put on the carb (stock Rochester B) from the old 216 that I took out of the truck. Then I found out (google was my friend) that the trottle hounsing on the 216 is narrower between the bolt holes than the trottle housing the 235 stock intake I have.
So, my question is:
Besides from the trottle housing, is the rest of the Rochester B the same on the 216 and 235?
In ohter words, do I need to find a complete ohter carb, or can I just change the trottle housing to the size that fits the 216 intake?
Thanks,
Martin
Moeller is offline   Reply With Quote
Old 01-19-2019, 04:52 PM   #2
Wrenchbender Ret
Re: 216 to 235 swap - carb. fitment problems?
You need to get the 235 carb. Ive seen ones that a guy cuts a slot in one of the mounting holes & used it that way but you will be loosing performance. The size of the throat is different. Same goes for the intake manifolds.
George
Wrenchbender Ret is offline   Reply With Quote
Old 01-19-2019, 04:56 PM   #3
Moeller
Yes, but do need to get a complete carb? - or can I just change the lower part (trottle housing)?
Old 01-19-2019, 07:07 PM   #4
Wrenchbender Ret
I'm not sure but I believe the throat in the fuel bowl is smaller too.
George
Old 01-19-2019, 07:27 PM   #5
Moeller
Ok, I guess its best to look for a complete 235 carb. Thanks!
